But the MIS Team refuses that method saying Oracle is mission critical for the company and changing anything to it may cause issue bla bla bla …….. Since we used to provide that service (On premise Exchange), my team should provide same method alternatives. Therefore I will not go down that path except for providing the alternative to my on premise exchange.
When I ran the command “openssl s_client -starttls imap -connect mailserver:143 | openssl x509 -noout -text”, I got the error below. Is there anything wrong with my setting? There is no issue when checking with port 587 and 443.
write:errno=104
unable to load certificate
140653554096016:error:0906D06C😛EM routines😛EM_read_bio:no start line:pem_lib.c:707:Expecting: TRUSTED CERTIFICATE
Below is the result when I query the certificate expiry date.
echo | openssl s_client -connect mailserver:143 -starttls imap 2>/dev/null | openssl x509 -inform pem -noout -enddate | cut -d “=” -f 2
140126333908880:error:0906D06C😛EM routines😛EM_read_bio:no start line:pem_lib.c:707:Expecting: TRUSTED CERTIFICATE
echo | openssl s_client -connect mailserver:143 -starttls imap 2>/dev/null | openssl x509 -inform pem -noout -enddate | cut -d "=" -f 2
140126333908880:error:0906D06C:PEM routines:PEM_read_bio:no start line:pem_lib.c:707:Expecting: TRUSTED CERTIFICATE
I got the same error when I query the certificate expiry date.
echo | openssl s_client -connect mailserver:587 -starttls smtp 2>/dev/null | openssl x509 -inform pem -noout -enddate | cut -d “=” -f 2
a
Something went wrong in my earlier entry. Checking on how to edit it
