DocFraggle thanks for chiming in!
So far, the only thing I’ve been able to link to those accounts unable to load SOGo interface (facing this blank page) is the repeated error in SOGo logs.
- First request passes
- SOGoCache gives the “ITEM TOO BIG” error
- WOWatchDogChild informs me that the pid has been hanging for some minutes
- WOHttpTransaction tells me client disconnected during delivery of response “the socket was shutdown”
See in order:
[60]: SOME_RANDOM_IP_ADDRESS "GET /SOGo/so/REDACTED/Mail/view HTTP/1.0" 200 2717519/0 2.646 4093923 33% 59M - 13
[59]: <0x0x55a22ac96980[SOGoCache]> an error occurred when caching value for key REDACTED@REDACTED.net+defaults': "ITEM TOO BIG"
[9]: [WARN] <0x0x55a22aeeecd0[WOWatchDogChild]> pid 61 has been hanging in the same request for 1 minutes
[9]: [WARN] <0x0x55a22aeeecd0[WOWatchDogChild]> pid 61 has been hanging in the same request for 2 minutes
[61]: [ERROR] <0x0x55a22c4948e0[WOHttpTransaction]> client disconnected during delivery of response for <WORequest[0x0x55a22ed14fc0]: method=GET uri=/SOGo/so/REDACTED@REDACTED.net/Mail/0/view app=SOGo rqKey=so rqPath=REDACTED@REDACTED.net/Mail/0/view> (len=24052): the socket was shutdown
Thanks again all for your help. Much appreciated.
Thanks for the suggestion, did this. Here are the logs since the restart was initiated:
sogo-mailcow-1 | 2024-08-31 09:42:04,548 WARN received SIGTERM indicating exit request
sogo-mailcow-1 | 2024-08-31 09:42:04,566 INFO waiting for processes, syslog-ng, bootstrap-sogo to die
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aef0c20[WOWatchDogChild]> sending terminate signal to pid 65
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aef19e0[WOWatchDogChild]> sending terminate signal to pid 64
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeefd70[WOWatchDogChild]> sending terminate signal to pid 63
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeeeae0[WOWatchDogChild]> sending terminate signal to pid 62
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeeecd0[WOWatchDogChild]> sending terminate signal to pid 61
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeeeee0[WOWatchDogChild]> sending terminate signal to pid 60
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeef3f0[WOWatchDogChild]> sending terminate signal to pid 59
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeef4a0[WOWatchDogChild]> sending terminate signal to pid 58
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeef860[WOWatchDogChild]> sending terminate signal to pid 57
sogo-mailcow-1 | Aug 31 09:42:04 826edfba5f83 sogod [9]: <0x0x55a22aeefc20[WOWatchDogChild]> sending terminate signal to pid 56
sogo-mailcow-1 | Aug 31 09:42:05 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:06 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:07 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | 2024-08-31 09:42:07,783 INFO waiting for processes, syslog-ng, bootstrap-sogo to die
sogo-mailcow-1 | Aug 31 09:42:08 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:09 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:10 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | 2024-08-31 09:42:10,783 INFO waiting for processes, syslog-ng, bootstrap-sogo to die
sogo-mailcow-1 | Aug 31 09:42:11 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:12 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:13 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | Aug 31 09:42:14 826edfba5f83 sogod [9]: <0x0x55a22adf2da0[WOWatchDog]> Terminating with SIGINT or SIGTERM
sogo-mailcow-1 | 2024-08-31 09:42:14,283 INFO waiting for processes, syslog-ng, bootstrap-sogo to die
sogo-mailcow-1 | 2024-08-31 09:42:15,412 INFO Set uid to user 0 succeeded
sogo-mailcow-1 | 2024-08-31 09:42:15,414 INFO supervisord started with pid 1
sogo-mailcow-1 | 2024-08-31 09:42:16,418 INFO spawned: 'processes' with pid 6
sogo-mailcow-1 | 2024-08-31 09:42:16,422 INFO spawned: 'syslog-ng' with pid 7
sogo-mailcow-1 | 2024-08-31 09:42:16,428 INFO spawned: 'bootstrap-sogo' with pid 8
sogo-mailcow-1 | Uptime: 69467 Threads: 18 Questions: 113669 Slow queries: 0 Opens: 141 Open tables: 48 Queries per second avg: 1.636
sogo-mailcow-1 | [2024-08-31T09:42:16.514520] WARNING: With use-dns(no), dns-cache() will be forced to 'no' too!;
sogo-mailcow-1 | DB schema is 29072024_1000
sogo-mailcow-1 | We are master, preparing sogo_view...
sogo-mailcow-1 | Aug 31 09:42:16 826edfba5f83 syslog-ng[7]: syslog-ng starting up; version='3.38.1'
sogo-mailcow-1 | We are master, preparing _sogo_static_view...
sogo-mailcow-1 | Updating _sogo_static_view content...
sogo-mailcow-1 | We are master, preparing update trigger...
sogo-mailcow-1 | Syncing web content with named volume
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: version 5.11.0 (build root@sleipnir 202408121451) -- starting
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: vmem size check enabled: shutting down app when vmem > 512 MB. Currently at 84 MB
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca6697b0c0[SOGoProductLoader]> SOGo products loaded from '/usr/lib/GNUstep/SOGo':
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca6697b0c0[SOGoProductLoader]> Contacts.SOGo, MailPartViewers.SOGo, SchedulerUI.SOGo, ActiveSync.SOGo, ContactsUI.SOGo, MailerUI.SOGo, Appointments.SOGo, AdministrationUI.SOGo, CommonUI.SOGo, MainUI.SOGo, PreferencesUI.SOGo, Mailer.SOGo
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: All products loaded - current memory usage at 95 MB
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> listening on 0.0.0.0:20000
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> watchdog process pid: 8
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x7fbb62578060[WOWatchDogChild]> watchdog request timeout set to 30 minutes
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> preparing 10 children
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 55
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 56
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 57
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 58
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 59
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 60
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 61
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 62
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 63
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [8]: <0x0x55ca66992e60[WOWatchDog]> child spawned with pid 64
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [55]: <0x0x55ca669c1a50[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [57]: <0x0x55ca669a2840[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [62]: <0x0x55ca669a2a30[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [63]: <0x0x55ca669abeb0[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [59]: <0x0x55ca669a29f0[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [60]: <0x0x55ca669cd400[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [56]: <0x0x55ca669a2a30[WOHttpAdaptor]> notified the watchdog that we are readyAug 31 09:42:17 sogod [58]: <0x0x55ca669a16f0[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [61]: <0x0x55ca669c1a90[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | Aug 31 09:42:17 826edfba5f83 sogod [64]: <0x0x55ca669f17f0[WOHttpAdaptor]> notified the watchdog that we are ready
sogo-mailcow-1 | 2024-08-31 09:42:18,394 INFO success: processes entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
sogo-mailcow-1 | 2024-08-31 09:42:18,394 INFO success: syslog-ng entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
sogo-mailcow-1 | 2024-08-31 09:42:18,394 INFO success: bootstrap-sogo entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: |SOGo| starting method 'GET' on uri '/SOGo/so/REDACTED@REDACTED.net'
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: <0x0x55ca66930280[SOGoCache]> Cache cleanup interval set every 900.000000 seconds
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: <0x0x55ca66930280[SOGoCache]> Using host(s) 'memcached' as server(s)
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: |SOGo| request took 0.013753 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: 2a01:e0a:95e:d030:1178:2af0:b747:c15a "GET /SOGo/so/REDACTED@REDACTED.net HTTP/1.0" 302 0/0 0.019 - - 1M - 12
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: |SOGo| starting method 'GET' on uri '/SOGo/so/REDACTED@REDACTED.net/view'
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: <0x0x55ca66930280[SOGoCache]> an error occurred when caching value for key 'REDACTED@REDACTED.net+defaults': "ITEM TOO BIG"
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: [WARN] <0x0x7fbb625997c0[WOxElemBuilder]> could not locate builders: WOxExtElemBuilder,WOxExtElemBuilder
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: |SOGo| request took 0.116626 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: 2a01:e0a:95e:d030:1178:2af0:b747:c15a "GET /SOGo/so/REDACTED@REDACTED.net/view HTTP/1.0" 302 0/0 0.118 - - 27M - 11
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: |SOGo| starting method 'GET' on uri '/SOGo/so/REDACTED@REDACTED.net/Mail'
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: |SOGo| request took 0.002670 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: 2a01:e0a:95e:d030:1178:2af0:b747:c15a "GET /SOGo/so/REDACTED@REDACTED.net/Mail HTTP/1.0" 302 0/0 0.005 - - 0 - 11
sogo-mailcow-1 | Aug 31 09:42:23 826edfba5f83 sogod [64]: |SOGo| starting method 'GET' on uri '/SOGo/so/REDACTED@REDACTED.net/Mail/view'
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [64]: |SOGo| request took 2.777327 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [64]: 2a01:e0a:95e:d030:1178:2af0:b747:c15a "GET /SOGo/so/REDACTED@REDACTED.net/Mail/view HTTP/1.0" 200 2717522/0 2.979 4093923 33% 103M - 12
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [64]: |SOGo| starting method 'GET' on uri '/SOGo/so/REDACTED@REDACTED.net/Calendar/alarmslist?browserTime=1725090146'
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [61]: |SOGo| starting method 'POST' on uri '/SOGo/so/REDACTED@REDACTED.net/Mail/0/folderINBOX/changes'
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [61]: <0x0x55ca668b4660[SOGoCache]> Cache cleanup interval set every 900.000000 seconds
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [61]: <0x0x55ca668b4660[SOGoCache]> Using host(s) 'memcached' as server(s)
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [64]: <0x0x55ca68e234d0[SOGoWebDAVAclManager]> entry '{DAV:}write' already exists in DAV permissions table
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [64]: <0x0x55ca68e234d0[SOGoWebDAVAclManager]> entry '{DAV:}write-properties' already exists in DAV permissions table
sogo-mailcow-1 | Aug 31 09:42:26 826edfba5f83 sogod [64]: <0x0x55ca68e234d0[SOGoWebDAVAclManager]> entry '{DAV:}write-content' already exists in DAV permissions table
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [56]: |SOGo| starting method 'GET' on uri '/SOGo/so/REDACTED@REDACTED.net/Mail/0/view'
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [56]: <0x0x55ca6694d320[SOGoCache]> Cache cleanup interval set every 900.000000 seconds
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [56]: <0x0x55ca6694d320[SOGoCache]> Using host(s) 'memcached' as server(s)
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [64]: <0x0x55ca66930280[SOGoCache]> an error occurred when caching value for key 'REDACTED@REDACTED.net+defaults': "ITEM TOO BIG"
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [61]: <0x0x55ca668b4660[SOGoCache]> an error occurred when caching value for key 'REDACTED@REDACTED.net+defaults': "ITEM TOO BIG"
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [56]: <0x0x55ca6694d320[SOGoCache]> an error occurred when caching value for key 'REDACTED@REDACTED.net+defaults': "ITEM TOO BIG"
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [64]: |SOGo| request took 0.091582 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:27 826edfba5f83 sogod [64]: 2a01:e0a:95e:d030:1178:2af0:b747:c15a "GET /SOGo/so/REDACTED@REDACTED.net/Calendar/alarmslist?browserTime=1725090146 HTTP/1.0" 200 60/0 0.095 - - 0 - 13
sogo-mailcow-1 | Aug 31 09:42:28 826edfba5f83 sogod [61]: |SOGo| request took 1.627126 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:28 826edfba5f83 sogod [61]: 2a01:e0a:95e:d030:1178:2af0:b747:c15a "POST /SOGo/so/REDACTED@REDACTED.net/Mail/0/folderINBOX/changes HTTP/1.0" 200 28/126 1.631 - - 27M - 13
sogo-mailcow-1 | Aug 31 09:42:33 826edfba5f83 sogod [61]: |SOGo| starting method 'GET' on uri '/SOGo.index/'
sogo-mailcow-1 | Aug 31 09:42:33 826edfba5f83 sogod [61]: [WARN] <0x0x7fbb625997c0[WOxElemBuilder]> could not locate builders: WOxExtElemBuilder,WOxExtElemBuilder
sogo-mailcow-1 | Aug 31 09:42:33 826edfba5f83 sogod [61]: |SOGo| request took 0.050120 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:33 826edfba5f83 sogod [61]: mailcowdockerized-watchdog-mailcow-1.mailcowdockerized_mailcow-network "GET /SOGo.index/ HTTP/1.1" 200 2644/0 0.053 - - 1M - 12
sogo-mailcow-1 | Aug 31 09:42:51 826edfba5f83 sogod [61]: |SOGo| starting method 'GET' on uri '/SOGo'
sogo-mailcow-1 | Aug 31 09:42:51 826edfba5f83 sogod [61]: |SOGo| request took 0.026636 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:51 826edfba5f83 sogod [61]: 135.181.154.30 "GET /SOGo HTTP/1.0" 302 0/0 0.029 - - 0 - 12
sogo-mailcow-1 | Aug 31 09:42:51 826edfba5f83 sogod [61]: |SOGo| starting method 'GET' on uri '/SOGo/'
sogo-mailcow-1 | Aug 31 09:42:51 826edfba5f83 sogod [61]: |SOGo| request took 0.004343 seconds to execute
sogo-mailcow-1 | Aug 31 09:42:51 826edfba5f83 sogod [61]: 135.181.154.30 "GET /SOGo/ HTTP/1.0" 200 2644/0 0.006 - - 0 - 12
Finally after a while, I get the following, and the page loads:
sogo-mailcow-1 | Aug 31 09:44:34 826edfba5f83 sogod [56]: |SOGo| request took 127.690689 seconds to execute
And finally indeed, confirming that with a timer on the user side. It loads after +2min:
