Servus,
I have some questions based on a particular use case. We have a test domain in our organisation : dev.organisation.com. I am trying to set up a mail server serving that domain which will be mail.dev.organisation.com.
Within that test domain I want email to be send and received so that abc@dev.organisation.com can send email to xyz@dev.organisation,com. That much is easy.
What I would now like to do is relay all mail where the address is NOT in @dev.organisation.com through our existing outgoing mail relay. eg @organisation.com, @gmail.com etc all gets relayed through mail.organisation.com.
Can that be easily configured with mailcow? I don’t necessarily need detailed instructions, just an answer to whether or not mailcow can handle such a setup. (Though instructions would be awesome!)
Kind regards,
Dave White
English
Test domain relay question
- Edited
DaveWhite I don’t necessarily need detailed instructions,
System - Routing - Sender-dependent transports
Feel free to ask if you need more detailed instructions
Thank you very much! I’ll go ahead with the installation and come back if I need more help :-)
