• Community Support
  • USEnglish
  • Be careful with update from 2024-07 to 2024-08 leads to dns error in unbound
I just installed the update. My system is Debian12 on Arm. No problems, everything works as it should
pkernstock Maybe something’s blocking DNS queries on your firewall?
If so as you assume IMVHO logically the version 2024-07 must not work.
Any query from LAN to port 53 is redirected to the opnsense. Opnsense is configured to use unbound. Forwarded ports from the opnsense to the mailcow are 25, 465 and 587.
Again, this setup is working flawlessly to the monent. I restored to 2024-07. No problems at all.
Alright, for a test I’ll forward the port 53 to the mailcow. I let you know.
    stefan21
    While the mailcow team shuffled things around a bit in the Unbound container’s healtcheck.sh, the check itself remained the same. It tries to resolve three different domains using Unbound inside the container:
    dig +short +timeout=2 +tries=1 "$domain" @127.0.0.1
    According to your error messages, all three fail.
    Did you try entering the Unbound container to manually check if DNS resolution works?
      pkernstock docker logs –tail=150 mailcowdockerized-unbound-mailcow-1
      Here the output:
      Setting console permissions…
      Receiving anchor key…
      Receiving root hints…
      setup in directory /etc/unbound
      Certificate request self-signature ok
      subject=CN=unbound-control
      removing artifacts
      Setup success. Certificates created. Enable in unbound.conf file to use
      2024-08-19 19:39:05,215 INFO Set uid to user 0 succeeded
      2024-08-19 19:39:05,219 INFO supervisord started with pid 1
      2024-08-19 19:39:06,227 INFO spawned: ‘processes’ with pid 22
      2024-08-19 19:39:06,236 INFO spawned: ‘syslog-ng’ with pid 23
      2024-08-19 19:39:06,246 INFO spawned: ‘unbound’ with pid 24
      2024-08-19 19:39:06,254 INFO spawned: ‘unbound-healthcheck’ with pid 25
      [1724089146] unbound[24:0] notice: init module 0: validator
      [1724089146] unbound[24:0] notice: init module 1: iterator
      Aug 19 19:39:06 1b9362a6bf20 syslog-ng[23]: syslog-ng starting up; version=‘4.7.1’
      [1724089146] unbound[24:0] info: start of service (unbound 1.20.0).
      2024-08-19 19:39:07,312 INFO success: processes entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-19 19:39:07,312 INFO success: syslog-ng entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-19 19:39:07,313 INFO success: unbound entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-19 19:39:07,313 INFO success: unbound-healthcheck entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-19 19:39:12: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:39:12: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:39:12: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:39:12: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-19 19:39:12: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-19 19:39:13: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-19 19:39:13: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-19 19:39:13: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-19 19:39:13: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-19 19:39:13: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-19 19:39:13: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-19 19:39:13: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-19 19:39:13: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-19 19:39:49: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:39:49: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:39:49: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:39:49: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-19 19:39:49: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-19 19:39:49: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-19 19:39:49: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-19 19:39:49: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-19 19:39:50: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-19 19:39:50: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-19 19:39:50: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-19 19:39:50: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-19 19:39:50: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-19 19:40:26: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:40:26: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:40:26: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-19 19:40:26: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-19 19:40:26: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-19 19:40:26: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-19 19:40:26: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-19 19:40:26: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-19 19:40:26: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-19 19:40:27: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-19 19:40:27: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-19 19:40:27: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-19 19:40:27: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      accolon Did you try entering the Unbound container to manually check if DNS resolution works?
      Here’s the info:
      docker compose exec unbound-mailcow /bin/bash
      1b9362a6bf20:/# ping -c2 1.1.1.1
      PING 1.1.1.1 (1.1.1.1): 56 data bytes
      64 bytes from 1.1.1.1: seq=0 ttl=53 time=30.357 ms
      64 bytes from 1.1.1.1: seq=1 ttl=53 time=21.828 ms
      — 1.1.1.1 ping statistics —
      2 packets transmitted, 2 packets received, 0% packet loss
      round-trip min/avg/max = 21.828/26.092/30.357 ms
      1b9362a6bf20:/# ping -c2 9.9.9.9
      PING 9.9.9.9 (9.9.9.9): 56 data bytes
      64 bytes from 9.9.9.9: seq=0 ttl=54 time=37.348 ms
      64 bytes from 9.9.9.9: seq=1 ttl=54 time=30.712 ms
      — 9.9.9.9 ping statistics —
      round-trip min/avg/max = 30.712/34.030/37.348 ms
      1b9362a6bf20:/# ping -c2 8.8.8.8
      PING 8.8.8.8 (8.8.8.8): 56 data bytes
      64 bytes from 8.8.8.8: seq=0 ttl=113 time=31.186 ms
      64 bytes from 8.8.8.8: seq=1 ttl=113 time=22.515 ms
      — 8.8.8.8 ping statistics —
      round-trip min/avg/max = 22.515/26.850/31.186 ms
      and:
      dig +short +timeout=2 +tries=1 fuzzy.mailcow.email
      95.217.129.125
      dig +short +timeout=2 +tries=1 github.com
      140.82.121.4
      dig +short +timeout=2 +tries=1 hub.docker.com
      elb-default.us-east-1.aws.dckr.io.
      prodextdefgreen-k0uuibjyui-4ec6503f7037d339.elb.us-east-1.amazonaws.com.
      44.219.3.189
      3.224.227.198
      44.193.181.103
      What exactly does ip-forwarding?
      forward-zone:
      forward-addr: ip-of-opnsense where unbound is running as DNS
      If in unbound.conf configured like this, the container starts “healthy”. Mailcow is running flawlessly.
      stefan21 Alright, for a test I’ll forward the port 53 to the mailcow. I let you know.
      Does not work.
      For another test I disabled the forward-zone follwed by docker compose down and docker compose up -d.
      From the cli: ✘ Container mailcowdockerized-unbound-mailcow-1 Error
      dependency failed to start: container mailcowdockerized-unbound-mailcow-1 is unhealthy
      Checking the gui reports:
      unbound-mailcow (mailcow/unbound:1.23)
      (Gestartet am 20.08.2024, 20:43:31)
      Läuft . . .
      Now what? Bug?
      Alright. There’s an update 2024-08a. I’ll test and report.
      After update to 2024-08a:
      The gui reports:
      (Gestartet am 20.08.2024, 21:12:06)
      Läuft . . .
      removing artifacts
      2024-08-20 21:12:12,220 INFO Set uid to user 0 succeeded
      2024-08-20 21:12:12,224 INFO supervisord started with pid 1
      2024-08-20 21:12:13,230 INFO spawned: ‘processes’ with pid 22
      2024-08-20 21:12:13,237 INFO spawned: ‘syslog-ng’ with pid 23
      2024-08-20 21:12:13,243 INFO spawned: ‘unbound’ with pid 24
      2024-08-20 21:12:13,247 INFO spawned: ‘unbound-healthcheck’ with pid 25
      [1724181133] unbound[24:0] notice: init module 0: validator
      [1724181133] unbound[24:0] notice: init module 1: iterator
      Aug 20 21:12:13 a6613c8891ac syslog-ng[23]: syslog-ng starting up; version=‘4.7.1’
      [1724181133] unbound[24:0] info: start of service (unbound 1.20.0).
      2024-08-20 21:12:14,316 INFO success: processes entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-20 21:12:14,316 INFO success: syslog-ng entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-20 21:12:14,316 INFO success: unbound entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-20 21:12:14,316 INFO success: unbound-healthcheck entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
      2024-08-20 21:12:19: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:12:19: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:12:19: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:12:19: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:12:19: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:12:19: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:12:19: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:12:19: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:12:19: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:12:20: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:12:20: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:12:20: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:12:20: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:12:56: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:12:56: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:12:56: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:12:56: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:12:56: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:12:56: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:12:56: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:12:56: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:12:56: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:12:57: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:12:57: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:12:57: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:12:57: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:13:33: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:13:34: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:13:34: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:13:34: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:14:10: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:14:11: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:14:11: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:14:11: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:14:47: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:14:47: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:15:24: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:15:24: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:16:00: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:16:00: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:16:01: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:16:01: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:16:01: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:16:01: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:16:37: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:16:37: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:16:37: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:16:37: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:16:38: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:16:38: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:16:38: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:16:38: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:16:38: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:16:38: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:16:38: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:16:38: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:16:38: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      2024-08-20 21:17:14: Healthcheck: DNS Resolution Failed on attempt 1 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:17:14: Healthcheck: DNS Resolution Failed on attempt 2 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:17:14: Healthcheck: DNS Resolution Failed on attempt 3 for fuzzy.mailcow.email! Trying again…
      2024-08-20 21:17:14: Healthcheck: DNS Resolution not possible after 3 attempts for fuzzy.mailcow.email… Gave up!
      2024-08-20 21:17:14: Healthcheck: DNS Resolution Failed on attempt 1 for github.com! Trying again…
      2024-08-20 21:17:15: Healthcheck: DNS Resolution Failed on attempt 2 for github.com! Trying again…
      2024-08-20 21:17:15: Healthcheck: DNS Resolution Failed on attempt 3 for github.com! Trying again…
      2024-08-20 21:17:15: Healthcheck: DNS Resolution not possible after 3 attempts for github.com… Gave up!
      2024-08-20 21:17:15: Healthcheck: DNS Resolution Failed on attempt 1 for hub.docker.com! Trying again…
      2024-08-20 21:17:15: Healthcheck: DNS Resolution Failed on attempt 2 for hub.docker.com! Trying again…
      2024-08-20 21:17:15: Healthcheck: DNS Resolution Failed on attempt 3 for hub.docker.com! Trying again…
      2024-08-20 21:17:15: Healthcheck: DNS Resolution not possible after 3 attempts for hub.docker.com… Gave up!
      2024-08-20 21:17:15: Healthcheck: Too many DNS failures (1 failures allowed, you got 3 failures), marking Healthcheck as unhealthy…
      Inside the unbound container:
      ping -c2 1.1.1.1
      64 bytes from 1.1.1.1: seq=0 ttl=53 time=42.549 ms
      64 bytes from 1.1.1.1: seq=1 ttl=53 time=23.276 ms
      round-trip min/avg/max = 23.276/32.912/42.549 ms
      a6613c8891ac:/# ping -c2 9.9.9.9
      64 bytes from 9.9.9.9: seq=0 ttl=54 time=53.028 ms
      64 bytes from 9.9.9.9: seq=1 ttl=54 time=27.660 ms
      round-trip min/avg/max = 27.660/40.344/53.028 ms
      a6613c8891ac:/# ping -c2 8.8.8.8
      64 bytes from 8.8.8.8: seq=0 ttl=113 time=34.309 ms
      64 bytes from 8.8.8.8: seq=1 ttl=113 time=21.203 ms
      dig +short github.com
      140.82.121.3
      a6613c8891ac:/# dig +short fuzzy.mailcow.email
      95.217.129.125
      a6613c8891ac:/# dig +short hub.docker.com
      44.219.3.189
      3.224.227.198
      44.193.181.103
      nslookup community.mailcow.email
      Server: 127.0.0.11
      Address: 127.0.0.11#53
      Non-authoritative answer:
      community.mailcow.email canonical name = web01.kernstock.net.
      Address: 5.1.87.87
      nslookup google.de 127.0.0.11
      Server: 127.0.0.11
      Address: 216.58.206.67
      Address: 2a00:1450:4001:81d::2003
      Weird. I don’t get it.
        The GUI reports:
        Report from docker logs –tail=150 mailcowdockerized-unbound-mailcow-1
        What version is running?
          stefan21 What version is running?
          Unbound 1.20 inside a Docker container based on mailcow’s latest  Icon container image tagged as version 1.23
          . These are different version numbers.
          stefan21 a6613c8891ac:/# dig +short fuzzy.mailcow.email
          95.217.129.125
          I don’t get this, either. Looks like DNS resolution is working, so no idea why the healthcheck script thinks it doesn’t.
          The script logs an error when either the dig command doesn’t return error code 0 or its output is empty:
          mailcow/mailcow-dockerizedblob/8971b11c49bde0899cc5c3ea49c3e8c975af54ee/data/Dockerfiles/unbound/healthcheck.sh#L56
          If I was affected, I would probably build a minimal version of healthcheck.sh with just the check_dnspart and try to debug this…
            accolon Looks like DNS resolution is working
            Yes. Ping is working, dig is working and dnslookup is working from inside of the container.
            I’m not happy with tweaking on email servers. I’d like to have this part of IT really stable and slow.
            I suggest you edit your data/Dockerfiles/unbound/healthcheck.sh script and add some debug log output starting at line 53
            mailcow/mailcow-dockerizedblob/master/data/Dockerfiles/unbound/healthcheck.sh#L53
            For example, output the details of the dig command in $dig_output and maybe even the return code. The script just checks if rc=0, but maybe it’s not 0, dig can return multiple return codes apart from 1
            The script may still run things differently from you running commands inside the container
              Maybe something related to this particular issue where dockerd misbehaved apparently? mailcow/mailcow-dockerized6042
              What I’m confused about is: You said that unbound container isn’t starting properly. But you’re still running dig commands in the same container, right? Are you running them shortly before the container stops, or when you have your workaround in place?
              @pkernstock
              To clarify:
              Without a forward-zone:
              docker compose up -d leads to
              and:
              docker compose exec unbound-mailcow /bin/bash enters the container. Inside the container ping, dig and nslookup are working. Therefore I assume DNS is working.
              Defining a forward-zone to the opnsense leads to a healthy start of the unbound-container (all containers). No errors at all.
              Inside the container:
              nslookup fuzzy.mailcow.email
              Server: 127.0.0.11
              Address: 95.217.129.125
              less healthcheck.sh:
              for domain in “${domains[@]}” ; do
              success=false
              for ((i=1; i<=3; i++)); do
              dig_output=$(dig +short +timeout=2 +tries=1 “$domain” @127.0.0.1 2>/dev/null)
              dig_rc=$?
                  if [ $dig_rc -ne 0 ] || [ -z "$dig_output" ]; then
                      log_to_stdout "Healthcheck: DNS Resolution Failed on attempt $i for $domain! Trying again..."
                  else
                      success=true
                      break
                  fi
              done
              Testing:
              1.) dig +short +timeout=2 +tries=1 fuzzy.mailcow.email @127.0.0.1 is giving nothing back
              2.) dig +short +timeout=2 +tries=1 fuzzy.mailcow.email @127.0.0.11
              95.217.129.125
              Altering healthcheck.sh inside the container will not persist a restart.
                Must be the script.
                Disabled the forward-zone. Did a docker compose down followed by a docker compose up -d. Entered the unbound container and altered the healthcheck.sh to 127.0.0.11. Did a docker compose restart unbound-mailcow.
                [+] Restarting 1/1
                ✔ Container mailcowdockerized-unbound-mailcow-1 Started
                docker compose ps
                mailcowdockerized-unbound-mailcow-1 mailcow/unbound:1.23 “/docker-entrypoint.…” unbound-mailcow 24 minutes ago Up 11 minutes (healthy) 53/tcp, 53/udp
                I’ll define a forward-zone as workaround until this is fixed.
                  stefan21 altered the healthcheck.sh to 127.0.0.11
                  127.0.0.11 is Docker’s own internal DNS service. All containers use 127.0.0.11 to include internal names of Docker containers. Your change simply asks another DNS server instead of Unbound, which effectively makes the health check useless.
                  stefan21 1.) dig +short +timeout=2 +tries=1 fuzzy.mailcow.email @127.0.0.1 is giving nothing back
                  That’s why the health check fails, so it’s working correctly. In your tests above, I missed that you skipped the @127.0.0.1 part, i.e. you were not asking Unbound directly.
                  So the question now is why your Unbound is not resolving DNS requests.
                  DocFraggle I suggest you edit your data/Dockerfiles/unbound/healthcheck.sh script and add some debug log output starting at line 53
                  GitHub Icon mailcow/mailcow-dockerizedblob/master/data/Dockerfiles/unbound/healthcheck.sh#L53
                  Which brings me back to my suggestion from above… why don’t you have a deeper look and log the details from the healthcheck script?
                  Found it.
                  I’m redirecting all DNS requests from LAN to the opnsense. As I already wrote, on the opnsense UNBOUND is running. I have to think about creating seperate rules for the mailcow, or leave the workaround with the forward-zone.
                  Question remains why did it work in version 2024-07 (obviously because of changing the healthcheck script), and what reason for is DNS working inside of the unbound-container working with ping, dig and nslookup. Why in general, changing the script? Running mailcow behind a proper configured firewall will cause hickups.
                  I’ll stop this now. Maybe someone can mark this thread as solved or tell me, how to do it.
                  BTW - did I overlook something in the doku? Can’t find anything about this special? issue. Is it special to redirect any DNS request from a LAN to a firewall and let the firewall do the job? AFAIK there are reasons to configure a FW in this way…
                    I read this. I do understand. My opnsense is using unbound as resolver. Because I do know about the problems with external resolvers. There are reasons why a sysadmin forces any device in the LAN to use only the resolver from a firewall.
                    What I don’t like is drilling holes in a firewall… of course a mail server needs ports (25, 465, 587) to communicate with other mail servers. Why icmp and DNS can’t be used from a firewall, IDK.
                    Anyway - as I know the pro’s and con’s of my setup, I’ll stay with a forward-zone in the mailcow pointing to the IP of my opnsense.
                    You didn’t answer to my question, why the healthscript worked before. I didn’t change anything in my firewall. Do you know the reason?
