Hi!
My mailcow hostname is mail.example.com.
I have the problem that nginx is handling traffic on example.com and serving the mailcow ui and that also with the wrong certificate that is for mail.example.com. I used to have example.com set in the mailcow.conf as ADDITIONAL_SERVER_NAME. But i took it out again.
Now, I cant find any reason in the nginx configs (eg there is no server_name set to example.com, or default server) why it is behaving this way. I could set an explicit handling but I want to find the root cause as I think it is a bug in mailcow how it handles changes to the ADDITIONAL_SERVER_NAME parameter.
I have another issue which might be related: When setting up an account on thunderbird with autoconfig/autodiscover it gives a warning that I should add a security acception as the certificate is for the wrong name.
Any ideas how to find the root cause?
Happy to provide you with any logs that can be helpful.
Thank you and much love to all beings ❤️
EDIT: Just as a side note: I have an A record for example.com on the same ip as mail.example.com
