Hallo zusammen,
gibt es eine Möglichkeit das golbale Adressbuch zu bearbeiten? Z.B. Aliasadressen oder Adressen, die für alle User wichtig sind hinzufügen?
Viele Grüße
Stephen
  • Hallo,
    I think it is not possible to edit the GAL in SoGo (unless perhaps with LDAP back-end, so not with Mailcow). The GAL works fine as a list of Mailcow/SoGo users. The solution (or workaround you might call it) is to create a new shared address book and grant everyone access to it. This works great for my small Mailcow installation. 🙂 More information, from the Cow’s mouth, is here: https://github.com/mailcow/mailcow-dockerized/issues/773.
6 days later
Hallo zusammen,
hat niemand eine Idee? ;-)
Viele Grüße
Stephen
Hallo,
    • diekuh
      • volunteer
      Moolevel 110
    Hi, thanks, that’s correct. 🙂
    Hello,
    thank you für your answer, Gebemsea! That works for me.
    Have a nice day!
    Stephen
