watchdog-mailcow-1 | Waiting for Redis...
dovecot-mailcow-1 | Could not connect to Redis at redis:6379: Try again
dovecot-mailcow-1 | Waiting for Redis...
rspamd-mailcow-1 | Waiting for PHP on port 9001...
php-fpm-mailcow-1 | Could not connect to Redis at redis:6379: Try again
php-fpm-mailcow-1 | Waiting for Redis...
acme-mailcow-1 | Could not connect to Redis at redis:6379: Try again
acme-mailcow-1 | Waiting for Redis...
ofelia-mailcow-1 | 2024-07-17T11:20:54.001-04:00 common.go:125 ▶ NOTICE [Job "sogo_sessions" (625487f0c3e8)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool
-v expire-sessions ${SOGO_EXPIRE_SESSION} || exit 0"
ofelia-mailcow-1 | 2024-07-17T11:20:54.001-04:00 common.go:125 ▶ NOTICE [Job "dovecot_imapsync_runner" (73831be5c817)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/lo
cal/bin/imapsync_runner.pl || exit 0"
ofelia-mailcow-1 | 2024-07-17T11:20:54.001-04:00 common.go:125 ▶ NOTICE [Job "sogo_ealarms" (3b718a75e372)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealar
ms-notify -p /etc/sogo/sieve.creds || exit 0"
ofelia-mailcow-1 | 2024-07-17T11:20:54.002-04:00 common.go:125 ▶ NOTICE [Job "dovecot_trim_logs" (10f610695c0d)] Started - /bin/bash -c "[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin
/trim_logs.sh || exit 0"
ofelia-mailcow-1 | 2024-07-17T11:20:54.1-04:00 common.go:125 ▶ NOTICE [Job "dovecot_trim_logs" (10f610695c0d)] StdOut: Command redis-cli -h redis -p 6379 LTRIM ACME_LOG 0 9999 failed to execute, exit c
ode was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM POSTFIX_MAILLOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM DOVECOT_MAILLOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM SOGO_LOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM NETFILTER_LOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM AUTODISCOVER_LOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM API_LOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM RL_LOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | Command redis-cli -h redis -p 6379 LTRIM WATCHDOG_LOG 0 9999 failed to execute, exit code was 1
ofelia-mailcow-1 | 2024-07-17T11:20:54.1-04:00 common.go:125 ▶ NOTICE [Job "dovecot_trim_logs" (10f610695c0d)] StdErr: Could not connect to Redis at redis:6379: Try again
ofelia-mailcow-1 | Could not connect to Redis at redis:6379: Try again
ofelia-mailcow-1 | 2024-07-17T11:20:54.1-04:00 common.go:125 ▶ NOTICE [Job "dovecot_trim_logs" (10f610695c0d)] Finished in "97.852796ms", failed: false, skipped: false, error: none
ofelia-mailcow-1 | 2024-07-17T11:20:54.165-04:00 common.go:125 ▶ NOTICE [Job "dovecot_imapsync_runner" (73831be5c817)] Finished in "164.037525ms", failed: false, skipped: false, error: none
ofelia-mailcow-1 | 2024-07-17T11:20:54.194-04:00 common.go:125 ▶ NOTICE [Job "sogo_sessions" (625487f0c3e8)] StdErr: 2024-07-17 15:20:54.185 sogo-tool[85:85] Remove all sessions older than 480 min
ofelia-mailcow-1 | 2024-07-17 15:20:54.191 sogo-tool[85:85] No session to remove
ofelia-mailcow-1 | 2024-07-17T11:20:54.194-04:00 common.go:125 ▶ NOTICE [Job "sogo_sessions" (625487f0c3e8)] Finished in "192.807724ms", failed: false, skipped: false, error: none
ofelia-mailcow-1 | 2024-07-17T11:20:54.201-04:00 common.go:125 ▶ NOTICE [Job "sogo_ealarms" (3b718a75e372)] Finished in "199.48882ms", failed: false, skipped: false, error: none
This is a recent output after an upgrade. Rolling back now so my mail server is working.
