Apologies @esackbauer . The version is 2024-06c. It is running on a vm in proxmox, running ubuntu 22.04, with ufw running and enabled. I have the following for ufw currently:
22/tcp ALLOW Anywhere
80/tcp ALLOW Anywhere
443 ALLOW Anywhere
8433:8443/tcp ALLOW Anywhere
25/tcp ALLOW Anywhere
465/tcp ALLOW Anywhere
587/tcp ALLOW Anywhere
143/tcp ALLOW Anywhere
993/tcp ALLOW Anywhere
110/tcp ALLOW Anywhere
995/tcp ALLOW Anywhere
4190/tcp ALLOW Anywhere
22/tcp (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
8433:8443/tcp (v6) ALLOW Anywhere (v6)
25/tcp (v6) ALLOW Anywhere (v6)
465/tcp (v6) ALLOW Anywhere (v6)
587/tcp (v6) ALLOW Anywhere (v6)
143/tcp (v6) ALLOW Anywhere (v6)
993/tcp (v6) ALLOW Anywhere (v6)
110/tcp (v6) ALLOW Anywhere (v6)
995/tcp (v6) ALLOW Anywhere (v6)
4190/tcp (v6) ALLOW Anywhere (v6)
Port 80 responds.
I see this when I decode base64:
Parsing account key…
Parsing CSR…
Found domains: mail.domain.com
Getting directory…
Directory found!
Registering account…
Already registered! Account ID: https://acme-v02.api.letsencrypt.org/acme/acct/ACCOUNT
Creating new order…
Traceback (most recent call last):
File “/usr/bin/acme-tiny”, line 8, in <module>
sys.exit(main())
File “/usr/lib/python3.12/site-packages/acme_tiny.py”, line 195, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact, check_port=args.check_port)
File “/usr/lib/python3.12/site-packages/acme_tiny.py”, line 120, in get_crt
order, _, order_headers = _send_signed_request(directory[‘newOrder’], order_payload, “Error creating new order”)
File “/usr/lib/python3.12/site-packages/acme_tiny.py”, line 60, in _send_signed_request
return _do_request(url, data=data.encode(‘utf8’), err_msg=err_msg, depth=depth)
File “/usr/lib/python3.12/site-packages/acme_tiny.py”, line 46, in _do_request
raise ValueError(f"{0}:\nUrl: {1}\nData: {2}\nResponse Code: {3}\nResponse: {4}".format(err_msg, url, data, code, resp_data))
ValueError: Error creating new order:
Url: https://acme-v02.api.letsencrypt.org/acme/new-order
Response Code: 429
Response: {‘type’: ‘urn:ietf:params:acme:error:rateLimited’, ‘detail’: ‘Error creating new order : too many certificates (5) already issued for this exact set of domains in the last 168 hours: mail.domain.com, retry after 2024-07-13T23:05:21Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/’, ‘status’: 429}
Aside from the many attempts, I am unable to for example, use TLS as it shows its not trusted.
Of another note, this is running in a reverse proxy in cloudpanel. I do have a valid ssl from cloudpanel to the subdomain for management.
