Hi, i just tried to install mailcow on a fresh new Ubuntu VM.
Everything went fine up until first start.
But in the GUI i got
" What is happening?
Please do not stop the stack while we are initializing the database or do other preparations."
I waited but nothing changed so i went into the logs and saw
“php-fpm-mailcow-1 | Waiting for SQL…” gets spammed.
Anyone knows how to fix?
I tried multiple reinstalls and somewhat also got
“ php-fpm-mailcow-1 | Could not get mysql-mailcow container id… trying again. ”
Anyone knows what up here?
PS : Mysql logs doenst show anything wrong:
2024-07-07 19:22:01-02:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.25+mariaubu2004 started.
2024-07-07 19:22:02-02:00 [Note] [Entrypoint]: Switching to dedicated user ‘mysql’
2024-07-07 19:22:02-02:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.25+mariaubu2004 started.
2024-07-07 19:22:02-02:00 [Note] [Entrypoint]: MariaDB upgrade not required
2024-07-07 19:22:02 0 [Note] Starting MariaDB 10.5.25-MariaDB-ubu2004 source revision 29c185bd771ac441121468b3850d6dc8d13b8a1f as process 1
2024-07-07 19:22:02 0 [Note] InnoDB: Uses event mutexes
2024-07-07 19:22:02 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2024-07-07 19:22:02 0 [Note] InnoDB: Number of pools: 1
2024-07-07 19:22:02 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
2024-07-07 19:22:02 0 [Note] mysqld: O_TMPFILE is not supported on /tmp (disabling future attempts)
2024-07-07 19:22:02 0 [Note] InnoDB: Using Linux native AIO
2024-07-07 19:22:02 0 [Note] InnoDB: Initializing buffer pool, total size = 25165824, chunk size = 25165824
2024-07-07 19:22:02 0 [Note] InnoDB: Completed initialization of buffer pool
2024-07-07 19:22:02 0 [Note] InnoDB: 128 rollback segments are active.
2024-07-07 19:22:02 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2024-07-07 19:22:02 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12 MB. Physically writing the file full; Please wait …
2024-07-07 19:22:02 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12 MB.
2024-07-07 19:22:02 0 [Note] InnoDB: 10.5.25 started; log sequence number 45187; transaction id 20
2024-07-07 19:22:02 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
2024-07-07 19:22:02 0 [Note] InnoDB: Buffer pool(s) load completed at 240707 19:22:02
2024-07-07 19:22:02 0 [Note] Server socket created on IP: ‘::’.
2024-07-07 19:22:03 1 [Note] Event Scheduler: scheduler thread started with id 1
2024-07-07 19:22:03 0 [Note] mysqld: ready for connections.
Version: ‘10.5.25-MariaDB-ubu2004’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
PS : When i first started the container i got “ php-fpm-mailcow-1 | Waiting for SQL… ”
after i restarted the containers i now get
php-fpm-mailcow-1 | Uptime: 1 Threads: 2 Questions: 1 Slow queries: 0 Opens: 17 Open tables: 10 Queries per second avg: 1.000
Sorry the forum is bugy i cant edit / remove my duplicates ( Forum says error try to refresh page)
