• Community SupportUnbound
  • USEnglish
  • Unhealthy mailcowdockerized-unbound-mailcow-1: Failed to con. “www.internic.net”
I’m trying to get mailcow work with default settings on a fresh alpine (aarch64) with no firewall (iptables and nftables only), but there is some network issue.
My issue is similar to the following mailcow community Icon problem
: curl: (7) Failed to connect to “www.internic.net” port 443 after 3216 ms: Couldn’t connect to server.I was not able to bypass this by disabling ipv6.
curl -vo /tmp/root.hints https://www.internic.net/domain/named.cache
works from host but not from unbound container
Ports seem to be closed for an outer computer in LAN: bpa.st Icon View paste YVYA
My ip a from unbound container: bpa.st Icon View paste AYAQ
Here is ps aux | grep docker-proxy: bpa.st Icon View paste D55A
Seems like the problem is related to docker-proxy setup
    Here is my healthcheck.log
    8844ce6e22f6:/# cat /var/log/healthcheck.log
    2024-06-28 11:22:37: Please check your internet connection or firewall rules to fix this error, because a simple ping test should always go through from the unbound container!
    8844ce6e22f6:/# ping 1.1.1.1
    I know that this problem is setup specific but I’m installing mailcow on a fresh new Alpine without firewall. I’m ready to cooperate and trace packages. Please help.
    Here is my traceroute from unbound container:
    Sorry, wrong traceback copypaste. Right one:
    8844ce6e22f6:/# traceroute google.com
    traceroute to google.com (142.251.1.102), 30 hops max, 46 byte packets
     1  172.22.1.1 (172.22.1.1)  0.006 ms  0.013 ms  0.006 ms
     2  *  *  *
