I’m running mailcow behind an nginx reverse proxy.
Everything works as expected.
mail.example.com
proxy passes to mailcow ui and sogo.
I want to “obfuscate” what’s behind door number one, i.e. I want to return an empty page whenever someone accesses the base url (mail.example.com
) in the browser.
So I added this to my nginx.conf
server {
listen 443 ssl;
server_name mail.example.com;
ssl_certificate ...
ssl_certificate_key ...
location = / {
return 200;
location / {
proxy_pass http://172.17.0.1:8080/;
So that whenever someone accesses just the base url, nginx will return 200 with an empty body.
This works, as long as I am logged into the admin UI.
If you’re logged in, all the follow up urls are mail.example.com/debug
or mail.example.com/user
etc.
However, if you’re logged out, the login page of the admin panel doesn’t have a sub-path in the url, it’s just the base url.
Is there any way to have the login page on a dedicated landing page like mail.example.com/login
, for instance?
