Hello, I spend last 2 day connecting clients to mailcow using IMAP. If a client is Outlook (multiple version), some of “default” folders are not translated to language of client. Inbox is OK, but Trash and Junk are not translated. Some of those people do not speak English, so it is quiet problem for them.
So far i find this thread, I’m not sure if it is still current,… https://community.mailcow.email/d/259-imap-folders-in-french-language translation are now located in dovecot.folders.conf I can see correct translation for Trash like mailbox "Odstraněná pošta" {special_use = \Trash}not sure if I need to override this in extra.conf,…
Sadly those folder can be renamed in Outlook :-(
Also there is command outlook.exe /resetfoldernames but this create new folder in native language and keep old english one, this is also confusing having 2 folders, Sogo will for sure use “english version”. Sogo shows correct translation from the beginning. Also Thunderbird have no problem at all :-(
This image show folder after resetfoldernames in outlook
Before mailcow we were using simillar stack postifx/dovecot and so, this was not an issue.
I will be grateful for any advice
