yes, it’s the /var/lib/docker/containers folder which gets bigger and bigger.
correct, the screenshot shows the folder before i installed the last update. I think the update changed the id?!?
When i update Mailcow, the /dev/sda2 has 16,5 GB. After 2 days it is at 33,3 GB. It’s every week the same.
now after the update:
and the /var/lib/docker/volumes
