DocFraggle This is my vhost
`server {
listen 80;
listen [::]:80;
listen 443 ssl http2;
listen [::]:443 ssl http2;
{{ssl_certificate_key}}
{{ssl_certificate}}
server_name mail.fketllc.com;
{{root}}
{{nginx_access_log}}
{{nginx_error_log}}
if ($scheme != “https”) {
rewrite ^ https://$host$uri permanent;
location @reverse_proxy {
proxy_pass {{reverse_proxy_url}};
proxy_http_version 1.1;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection “Upgrade”;
proxy_pass_request_headers on;
proxy_max_temp_file_size 0;
proxy_connect_timeout 900;
proxy_send_timeout 900;
proxy_read_timeout 900;
proxy_buffer_size 128k;
proxy_buffers 4 256k;
proxy_busy_buffers_size 256k;
proxy_temp_file_write_size 256k;
{{settings}}
add_header Cache-Control no-transform;
index index.html;
location ^~ /.well-known {
auth_basic off;
allow all;
try_files $uri @reverse_proxy;
location / {
