Hi
If I want to change the score for MISSING_TO in Rspamd where is the best place to make this change?
I can see that I could add it in the “/data/conf/rspamd/local.d/composites.conf” but will it be replaced after an upgrade?
English
Hi
No, /data/conf is for all persistant settings and should survive an upgrade.
Roger
After cruising through the webui, I found that I could change the score in the dedicated Rspamd UI.
We will see if it takes effect :-)
