hi
in the mailcow settings you can create DKIM keys of 2048 bits max,
Is there a way to generate 4096 bit keys? THANKS
English
create 4096-bit DKIM keys with Mailcow
- Best Answerset by pkernstock
RFC 4871 was obsoleted by in 2011, which was updated by in 2018.
While the statement about the possible length constraints still holds, the key sizes have changed:
Signers SHOULD use RSA keys of at least 2048 bits.
Verifiers MUST be able to validate signatures with keys ranging from
1024 bits to 4096 bits, and they MAY be able to validate signatures
with larger keys.
4096 bit is still not required for security reasons, but it should be usable by now. Personally, I’d go with 2048.
