I use self-hosted mailcow server with my Internet Access Provider (iap) adress mail like “name@iap.fr” with sender-dependent transport “smtp.iap.fr:587”.
The test results of the SMTP transmission is ok, i see :
SERVER -> CLIENT: 250 2.0.0 k380rSxxxxxxx mail accepted for delivery.
…Unfortunately sometimes emails arrives in the receiver’s spam folder.
Please could you help in configuring correctly my settings ?
I think the issue concerns address rewritting but I’m not sure !
Is there a complete tuto regarding this subject ?
Thanks for your help,
Phil
If I understand correctly you are running your mailcow at home with your local ISP? That’s never a good idea as there are a lot of SMTP blacklists containing the ISP network ranges. You have to use a relay service to send your mails, otherwise most of your sent emails will be flagged as SPAM…
In case I didn’t understand: is smtp.iap.fr:587 your relay service?
  • Phil replied to this.
    I have a server running at home also.
    I use sendgrid for sending my emails.
    DocFraggle
    My server is not running at home but at the moment on a Contabo Virtual Private Server.
    Yes, i use my ISP/IAP smtp services for outgoing emails with a sender-dependant transport setting adress : smtp.iap.fr:587
    So i think my issue isn’t coming from IP blacklisting
    I suspect it comes from address rewriting in the message header….
    [unknown]
    Thanks for this alternative
    If i’s possible to solve this spam issue, I would prefer to use my provider’s SMTP for outgoing emails
    [unknown]
    Did you ever get the mail header of one of your recipients where your mail was flagged as SPAM? Maybe you can find a hint there if you check the X-SPAM* headers
