When setting the value of force_pw_update=1 in the create inbox API
“local_part”: “{{local_part}}”,
“domain”: “{{domain}}”,
“name”: “{{name}}”,
“password”: “{{password}}”,
“password2”: “{{password2}}”,
“active”: {{active}},
“force_pw_update”: {{force_password_update}}
[unknown]
Also encountering the error when creating the mailbox in mailcow admin panel.
[unknown]
[unknown]
You are right, it’s the same problem on my mailcow. Never tested this function before though…
Yes, that seems to be a bug, I’m currently debugging a little bit. Upon setting the force password reset option the password hash in the database view “sogo_view” changes to another value, and that’s the reason why you can’t login anymore. It’s switched back to the original hash after removing the checkbox again.
EDIT: It’s really strange as it seems to be intended: mailcow/mailcow-dockerizedblob/master/data/Dockerfiles/sogo/bootstrap-sogo.sh#L38
If the password change option is set (force_pw_update) then a static SSHA256 hash is set for the user so that he can’t login in SoGo.
BUT he can login into the mailcow UI and has to change his password there. I guess that’s because SoGo itself doesn’t have a password change function?
EDIT 2: just had a look, there is no option in SoGo to change your password through the SoGo UI, so that’s the reason. The user has to change the password via the mailcow UI
    6 days later
    chulim ah OK, but it still wouldn’t work due to the fixed SSHA256 hash which is set by mailcow…
