Thank you very much for the advice. I have already disabled IPv6 and now I only work with IPv4 but I still have the same problem. TLS is required, but was not offered by host gmail-smtp-in.l.google.com when I try to force TLS from the administration interface and it does not send the email but if I deactivate it sends the emails but without TLS.
Feb 27 20:08:08 a40f96583e16 postfix/qmgr[355]: 4ECA63AA6E24: from=blade-liger@bladeforwardtech.com, size=972, nrcpt=1 (queue active)
Feb 27 20:08:08 a40f96583e16 postfix/sogo/smtpd[370]: disconnect from mailcowdockerized-sogo-mailcow-1.mailcowdockerized_mailcow-network[172.22.1.248] ehlo=1 auth=1 mail=1 rcpt=1 data=1 quit=1 commands=6
Feb 27 20:08:19 a40f96583e16 enforced-tls-smtp/smtp[380]: 4ECA63AA6E24: TLS is required, but was not offered by host gmail-smtp-in.l.google.com[142.250.0.27]
Feb 27 20:08:30 a40f96583e16 enforced-tls-smtp/smtp[380]: 4ECA63AA6E24: TLS is required, but was not offered by host alt1.gmail-smtp-in.l.google.com[64.233.184.27]
Feb 27 20:08:41 a40f96583e16 enforced-tls-smtp/smtp[380]: 4ECA63AA6E24: TLS is required, but was not offered by host alt2.gmail-smtp-in.l.google.com[142.250.27.27]
Feb 27 20:08:51 a40f96583e16 enforced-tls-smtp/smtp[380]: 4ECA63AA6E24: TLS is required, but was not offered by host alt3.gmail-smtp-in.l.google.com[142.250.153.27]
Feb 27 20:09:02 a40f96583e16 enforced-tls-smtp/smtp[380]: 4ECA63AA6E24: to=pleczerowolfus@gmail.com, relay=alt4.gmail-smtp-in.l.google.com[142.251.9.27]:25, delay=55, delays=0.61/0.06/54/0, dsn=5.7.4, status=bounced (TLS is required, but was not offered by host alt4.gmail-smtp-in.l.google.com[142.251.9.27])
Feb 27 20:09:02 a40f96583e16 postfix/cleanup[388]: E183E3AA6E35: message-id=20250228000902.E183E3AA6E35@mail.bladeforwardtech.com
Feb 27 20:09:02 a40f96583e16 postfix/bounce[386]: 4ECA63AA6E24: sender non-delivery notification: E183E3AA6E35
Feb 27 20:09:02 a40f96583e16 postfix/qmgr[355]: E183E3AA6E35: from=<>, size=3756, nrcpt=1 (queue active)
Feb 27 20:09:02 a40f96583e16 postfix/qmgr[355]: 4ECA63AA6E24: removed
Feb 27 20:09:02 a40f96583e16 postfix/lmtp[391]: E183E3AA6E35: to=blade-liger@bladeforwardtech.com, relay=dovecot[172.22.1.250]:24, delay=0.08, delays=0.01/0.02/0/0.04, dsn=2.0.0, status=sent (250 2.0.0 blade-liger@bladeforwardtech.com 2HefOJ7+wGf9AAAAZw/OFw Saved)
Feb 27 20:09:02 a40f96583e16 postfix/qmgr[355]: E183E3AA6E35: removed
