DocFraggle I tried Docker version 24.0 and disabled ipv6, enable_ipv6: false, which solved the error, but after adding the domain in the backend, checking the DNS reported an error 504, where do I check the cause?
unbound-mailcow-1 | Setting console permissions...
unbound-mailcow-1 | Receiving anchor key...
unbound-mailcow-1 | Receiving root hints...
unbound-mailcow-1 | setup in directory /etc/unbound
unbound-mailcow-1 | removing artifacts
unbound-mailcow-1 | Setup success. Certificates created. Enable in unbound.conf file to use
unbound-mailcow-1 | [1708267381] unbound[1:0] notice: init module 0: validator
unbound-mailcow-1 | [1708267381] unbound[1:0] notice: init module 1: iterator
unbound-mailcow-1 | [1708267381] unbound[1:0] info: start of service (unbound 1.17.1).
unbound-mailcow-1 | [1708267385] unbound[1:0] info: generate keytag query _ta-4f66. NULL IN
unbound-mailcow-1 | [1708267399] unbound[1:0] info: service stopped (unbound 1.17.1).
unbound-mailcow-1 | [1708267399] unbound[1:0] info: server stats for thread 0: 34 queries, 0 answers from cache, 34 recursions, 0 prefetch, 0 rejected by ip ratelimiting
unbound-mailcow-1 | [1708267399] unbound[1:0] info: server stats for thread 0: requestlist max 56 avg 29.6765 exceeded 0 jostled 0
unbound-mailcow-1 | [1708267399] unbound[1:0] info: average recursion processing time 3.777173 sec
unbound-mailcow-1 | [1708267399] unbound[1:0] info: histogram of recursion processing times
unbound-mailcow-1 | [1708267399] unbound[1:0] info: [25%]=2.25 median[50%]=3.35714 [75%]=5.3
unbound-mailcow-1 | [1708267399] unbound[1:0] info: lower(secs) upper(secs) recursions
unbound-mailcow-1 | [1708267399] unbound[1:0] info: 0.524288 1.000000 2
unbound-mailcow-1 | [1708267399] unbound[1:0] info: 1.000000 2.000000 4
unbound-mailcow-1 | [1708267399] unbound[1:0] info: 2.000000 4.000000 14
unbound-mailcow-1 | [1708267399] unbound[1:0] info: 4.000000 8.000000 10
unbound-mailcow-1 | [1708267399] unbound[1:0] info: 8.000000 16.000000 1
unbound-mailcow-1 | [1708267442] unbound[1:0] notice: init module 0: validator
unbound-mailcow-1 | [1708267442] unbound[1:0] notice: init module 1: iterator
unbound-mailcow-1 | [1708267442] unbound[1:0] info: start of service (unbound 1.17.1).
unbound-mailcow-1 | [1708267447] unbound[1:0] info: generate keytag query _ta-4f66. NULL IN
