Hi, is there a way to reduce loglevel, eg log only warning or higher? I just saw that /var/log/messages is 1.6GB big after half months of use.
EnglishReduce loglevel
- Edited
Have you checked what is logged?
You should check what it is complaining about. My /var/log/messages is only 1 MB in total after 1 year.
But then I found out it stopped logging after 3-4 months. Can’t remember why.
Everything that “docker-compose logs” would print out lands in /var/log/messages. Hence the size and my wish to change the log level.
- Edited
Sorry for noob question, but where do I find a “/var/log/messages”?
In my “/opt/mailcow-dockerized” location there is nothing like this and also in “/var/log” there are no “messages”.
henningsieh Which OS are you using? It depends on the OS
RedHat derivates use /var/log/messages, Debian derivates use /var/log/syslog i.e.
- Edited
I run my Mailcow dockerized on a VPS at Contabo Hosting with an underlying Ubuntu 22.04.4 LTS.
“/opt/mailcow-dockerized” looks like this:
It’s at /var/log/syslog if you are running Ubuntu
Thank you, I found it with a size of 8 MB. :-)
root@vmd104158:/# ls -lh /var/log/syslog
-rw-r----- 1 syslog adm 8.1M Feb 16 09:12 /var/log/syslog
root@vmd104158:/#start to setup logrotation on your host
Ok, so it looks like podman saves all generated logs to /var/log/messages while normal docker discards that information. Sure I can redirect the logs and rotate and delete but why is mailcow so chatty to begin with? The logs you get from “docker-compose logs” are filled with too much useless information. Changing loglevel would be helpful to focus on the real important information.
