Hi
With the 2023-12 release a new toggle has turned up under Fail2ban parameters.
I find it hard to read, if it is turned on or off and there are now other visual cues to indicate the state.
So, can someone help an old man read the toggle, when is it on and when is it off?
  • Left = deactivated (greyed out, white)
    Right = activated (solid blue)
    I am also almost 60, but have no problem to read the state.
    When have you been to the oculist lately? ๐Ÿ˜‰
Hehe :-)
The problem is that, for me at least, when it is left it is a bright color in dark mode, and in other interfaces right is off. It helps a bit in light mode.
Also, there no other toggles to reference from (except dark mode toggle), so I couldnโ€™t find a way to get a visual cue.
But thanks for helping out, much appreciated.
A toggle switch that is situated on the left usually indicates โ€œoffโ€. As far as I can remember, this has always been the case on all graphical user interfaces I have used over the past 30 years. Btw. the same goes for all the physical toggle switches I have used over the past 100 years. ๐Ÿ˜‰
