Hello!
I am using Mailcow at home, on a machine running a Debian server installation. I am very happy with Mailcow and usually everything works fine. However, Rspamd seems to be experiencing cryptic errors, even though the service seems to be working and Watchdog does not seem to be noticing anything either. But when using the Rspamd UI, the output has several logged errors. I am not completely sure, but I think these errors have been showing up constantly ever since migrating a full installation from one server to another.
I tried searching for the errors, but I am not knowledgeable enough in the workings of Rspamd. These are the logs:
12/7/2023, 1:10:27 AM	controller	47	map	xxxxxx	cannot resolve urlhaus.abuse.ch: server fail
12/6/2023, 6:07:14 PM	main	1	map	xxxxxx	regexp map is empty
Is there anything I can do? Thank you in advance!
    esackbauer Thank you for your reply! Unfortunately, even though I went through the steps in the documentation (and deleted all .hs and .hsmp files), nothings has changed. The same errors are still there. Some have changed though:
    12/8/2023, 2:01:02 PM	main	1	map	esqk4o	regexp map is empty
    12/8/2023, 2:01:02 PM	main	1	map	amrk5d	regexp map is empty
    12/8/2023, 2:01:02 PM	main	1	map	d1sp7e	regexp map is empty
    12/8/2023, 2:01:02 PM	main	1	map	z7d36p	regexp map is empty
    12/8/2023, 2:01:02 PM	main	1	map	jnkfot	regexp map is empty
    12/8/2023, 2:01:02 PM	main	1	map	4ar9sf	regexp map is empty
    12/8/2023, 2:01:02 PM	main	1	map	e99k7g	regexp map is empty
    12/8/2023, 2:01:02 PM	main	1	cfg	xpdxne	action rewrite subject has no threshold being set and it is not a no threshold action
    12/8/2023, 2:01:01 PM	main	1	symcache	xpdxne	cannot find dependency on symbol MAILCOW_WHITE for symbol LOCAL_BL_ASN
    I am on the latest version too (2023-11a) and did the upgrade just yesterday. I was able to get the docker logs:
    logs-mailcow-dockerized-rspamd-2023-12-08.txt
    71kB
    esackbauer Got ya, thanks for clearing that up for me! I’ll just ignore it then. Have a nice day.
