I am using Docker on my VPS to run mailcow and separately i am using CloudPanel to Run my website.
everything was great while install as i have set my HTTPS Port to 8444 and 8080
And use Reverse proxy using CloudPanel and it’s works fine .
Suddenly i did restart and the Mailcow is not starting due to Nginx issue.
Error starting userland proxy: listen tcp4 MyIP:8080: bind: address already in use.
As i can understand my cloudpanel also using Nginx and the docker and mailcow also using Nginx
i need to change mailcow Nginx port - but how?
Thanks In Advance
