Hi, is there any chance you would consider moving the source code to a different provider than GitHub? I am trying to use mailcow in an ipv6-only environment, and it seems that github.com doesn’t work with ipv6. You can try this with a DNS lookup on its AAAA record:
nslookup -type=AAAA github.com
AWS is beginning to charge early next year for ipv4 addresses, so I’d like to move into ipv6 networking. GitHub is apparently in no hurry to convert.
Thanks.
