DerLinkman
o.O
cd /opt/mailcow-dockerized/ && /opt/mailcow-dockerized/update.sh
Detecting if your IP is listed on Spamhaus Bad ASN List…
Check completed! Your IP is clean
Checking internet connection… OK
Detecting which build your mailcow runs on…
You are receiving stable updates (master).
To change that run the update.sh Script one time with the –nightly parameter to switch to nightly builds.
Checking for newer update script…
remote: Enumerating objects: 11, done.
remote: Counting objects: 100% (11/11), done.
remote: Compressing objects: 100% (7/7), done.
remote: Total 11 (delta 4), reused 10 (delta 4), pack-reused 0
Unpacking objects: 100% (11/11), 7.12 KiB | 1.42 MiB/s, done.
From https://github.com/mailcow/mailcow-dockerized
5b8efeb2..a366494c master -> origin/master
f1c93fa3..99de302e staging -> origin/staging
- [new tag] 2023-10a -> 2023-10a
Updated 0 paths from a843066d
Great! Native IPv6 NAT is active.
Validating docker-compose stack configuration…
services.postfix-mailcow.depends_on.unbound-mailcow Additional property restart is not allowed
Oh no, something went wrong. Please check the error message above.
