Hi all
I want to consume the logs into Graylog but I can see that the time format is “%b %d %H:%M:%S ” when it arrives.
When looking in dovecot.conf I see that it should be in the format “%Y-%m-%d %H:%M:%S”.
My logs are sent vi docker (docker-compose.override.yml):
dovecot-mailcow: # or any other
logging:
driver: “syslog”
options:
syslog-address: “tcp+tls://syslog.example.com:514”
syslog-tls-ca-cert: “/etc/ssl/ca.pem”
tag: “dovecot-mailcow”
syslog-format: “rfc5424”
Don’t know if this has something to do with it.
  • lnxgeek replied to this.
  • lnxgeek
    It sould seem that it is related to some extractors, so it isn’t Dovecot related.
    lnxgeek
