Hi
What is the best way to only allow IMAPS for clients?
I don’t want clients to unintentionally connect via cleartext IMAP.
English
Disable IMAP and only allow IMAPS
Any modern mail client won’t let you connect unencrypted “unintentionally”.
Also there isn’t just IMAPS but also STARTTLS through the standard IMAP port. Just because it’s not IMAPS doesn’t mean it’s unencrypted.
I just want to be sure no one can communicate unencrypted even when they are phished or tricked in any way (or the client is broken).
- Edited
- Best Answerset by esackbauer
If you have a firewall in front of your server, you could simply block, or not allow/forward, the corresponding ports. If the server is directly connected to the internet, without a firewall in between, it gets more complicated. See here: and here:
Please make sure you fully understand how iptables, and specifically the DOCKER-USER chain works, before you start messing around with it on your production instance!
