• Feedback
  • DEGerman
  • ARM64: Mailcow broken after todays nightly update
Hi guys,
someone else here on Hetzner arm64?
I’ve tried todays nightly build update, but there seems to be a problem: if I open my mailcow hostname, there is only a blank page (SOGO still works) and the ActiveSync also doesn’t work anymore. I couldn’t find anything helpful in the logs. All containers are up.
Hopefully I did a snapshot just before the update and could easily roll back to the previous version.
Just as warning for other users here: always make a backup/snapshot before you update. Especially if you’re on nightly builds like me.
    11 days later
    jimmy_jummy Hey, verwende selber das Beta ARM Image bei Hetzner.
    Bei mir läuft alles einwandfrei. Habe aber beim Installieren den Master Branch gewählt. Muss aber ehrlicherweise zugeben das ich nicht weiß ob das aktuell überhaupt was ändert.
