email app on phone not connected to same network says imap.thetechnologystudio.com isn’t responding.
I am receiving and able to send emails from Sogo but imap seems to not work
smtp tests says working but unsure if fully working
I have attached photos of my configurations and uploaded my main maincow config.
Please help.
mailcow web ui configuration
example.org is not a valid hostname, use a fqdn here.
Default admin user is “admin”
Default password is “moohoo”
MAILCOW_HOSTNAME=mail.thetechnologystudio.com
Password hash algorithm
Only certain password hash algorithm are supported. For a fully list of supported schemes,
MAILCOW_PASS_SCHEME=BLF-CRYPT
SQL database configuration
DBNAME=mailcow
DBUSER=mailcow
Please use long, random alphanumeric strings (A-Za-z0-9)
DBPASS=xvD9sKT5LfVpJ8rmjF4zodUIFZp8
DBROOT=CHh1VpRBQqrtnDM13XHwv9rHZdpS
HTTP/S Bindings
You should use HTTPS, but in case of SSL offloaded reverse proxies:
Might be important: This will also change the binding within the container.
If you use a proxy within Docker, point it to the ports you set below.
Do not use IP😛ORT in HTTP(S)BIND or HTTP(S)PORT
IMPORTANT: Do not use port 8081, 9081 or 65510!
Example: HTTP_BIND=1.2.3.4
For IPv4 leave it as it is: HTTP_BIND= & HTTPS_PORT=
HTTP_PORT=80
HTTP_BIND=192.168.1.157
HTTPS_PORT=443
HTTPS_BIND=192.168.1.157
Other bindings
You should leave that alone
Format: 11.22.33.44:25 or 12.34.56.78:465 etc.
SMTP_PORT=25
SMTPS_PORT=465
SUBMISSION_PORT=587
IMAP_PORT=143
IMAPS_PORT=993
POP_PORT=110
POPS_PORT=995
SIEVE_PORT=4190
DOVEADM_PORT=127.0.0.1:19991
SQL_PORT=127.0.0.1:13306
SOLR_PORT=127.0.0.1:18983
REDIS_PORT=127.0.0.1:7654
Your timezone
Use the row named ‘TZ database name’ + pay attention for ‘Notes’ row
TZ=America/Toronto
Fixed project name
Please use lowercase letters only
COMPOSE_PROJECT_NAME=mailcowdockerized
Used Docker Compose version
Switch here between native (compose plugin) and standalone
For more informations take a look at the mailcow docs regarding the configuration options.
Normally this should be untouched but if you decided to use either of those you can switch it manually here.
Please be aware that at least one of those variants should be installed on your machine or mailcow will fail.
DOCKER_COMPOSE_VERSION=native
Set this to “allow” to enable the anyone pseudo user. Disabled by default.
When enabled, ACL can be created, that apply to “All authenticated users”
This should probably only be activated on mail hosts, that are used exclusivly by one organisation.
Otherwise a user might share data with too many other users.
ACL_ANYONE=disallow
Garbage collector cleanup
Deleted domains and mailboxes are moved to /var/vmail/_garbage/timestamp_sanitizedstring
How long should objects remain in the garbage until they are being deleted? (value in minutes)
Check interval is hourly
MAILDIR_GC_TIME=7200
Additional SAN for the certificate
You can use wildcard records to create specific names for every domain you add to mailcow.
Example: Add domains “example.com” and “example.net” to mailcow, change ADDITIONAL_SAN to a value like:
#ADDITIONAL_SAN=imap.,smtp.
This will expand the certificate to “imap.example.com”, “smtp.example.com”, “imap.example.net”, “smtp.example.net”
plus every domain you add in the future.
You can also just add static names…
#ADDITIONAL_SAN=srv1.example.net
…or combine wildcard and static names:
#ADDITIONAL_SAN=imap.*,srv1.example.com
ADDITIONAL_SAN=
Additional server names for mailcow UI
Specify alternative addresses for the mailcow UI to respond to
This is useful when you set mail.* as ADDITIONAL_SAN and want to make sure mail.maildomain.com will always point to the mailcow UI.
If the server name does not match a known site, Nginx decides by best-guess and may redirect users to the wrong web root.
You can understand this as server_name directive in Nginx.
Comma separated list without spaces! Example: ADDITIONAL_SERVER_NAMES=a.b.c,d.e.f
Skip running ACME (acme-mailcow, Let’s Encrypt certs) - y/n
SKIP_LETS_ENCRYPT=n
Create seperate certificates for all domains - y/n
this will allow adding more than 100 domains, but some email clients will not be able to connect with alternative hostnames
ENABLE_SSL_SNI=n
Skip IPv4 check in ACME container - y/n
SKIP_IP_CHECK=n
Skip HTTP verification in ACME container - y/n
SKIP_HTTP_VERIFICATION=n
Skip ClamAV (clamd-mailcow) anti-virus (Rspamd will auto-detect a missing ClamAV container) - y/n
SKIP_CLAMD=n
Skip SOGo: Will disable SOGo integration and therefore webmail, DAV protocols and ActiveSync support (experimental, unsupported, not fully implemented) - y/n
SKIP_SOGO=n
Skip Solr on low-memory systems or if you do not want to store a readable index of your mails in solr-vol-1.
SKIP_SOLR=n
Solr heap size in MB, there is no recommendation, please see Solr docs.
Solr is a prone to run OOM and should be monitored. Unmonitored Solr setups are not recommended.
SOLR_HEAP=1024
Allow admins to log into SOGo as email user (without any password)
ALLOW_ADMIN_EMAIL_LOGIN=n
Enable watchdog (watchdog-mailcow) to restart unhealthy containers
USE_WATCHDOG=y
Send watchdog notifications by mail (sent from watchdog@MAILCOW_HOSTNAME)
CAUTION:
1. You should use external recipients
2. Mails are sent unsigned (no DKIM)
3. If you use DMARC, create a separate DMARC policy (“v=DMARC1; p=none;” in _dmarc.MAILCOW_HOSTNAME)
Multiple rcpts allowed, NO quotation marks, NO spaces
#WATCHDOG_NOTIFY_EMAIL=a@example.com,b@example.com,c@example.com
Notify about banned IP (includes whois lookup)
WATCHDOG_NOTIFY_BAN=n
Subject for watchdog mails. Defaults to “Watchdog ALERT” followed by the error message.
#WATCHDOG_SUBJECT=
Checks if mailcow is an open relay. Requires a SAL. More checks will follow.
No data is collected. Opt-in and anonymous.
Will only work with unmodified mailcow setups.
WATCHDOG_EXTERNAL_CHECKS=n
Enable watchdog verbose logging
WATCHDOG_VERBOSE=n
Max log lines per service to keep in Redis logs
LOG_LINES=9999
Internal IPv4 /24 subnet, format n.n.n (expands to n.n.n.0/24)
IPV4_NETWORK=172.22.1
Internal IPv6 subnet in fc00::/7
IPV6_NETWORK=fd4d:6169:6c63:6f77::/64
Use this IPv4 for outgoing connections (SNAT)
#SNAT_TO_SOURCE=
Use this IPv6 for outgoing connections (SNAT)
#SNAT6_TO_SOURCE=
Create or override an API key for the web UI
You must define API_ALLOW_FROM, which is a comma separated list of IPs
An API key defined as API_KEY has read-write access
An API key defined as API_KEY_READ_ONLY has read-only access
Allowed chars for API_KEY and API_KEY_READ_ONLY: a-z, A-Z, 0-9, -
You can define API_KEY and/or API_KEY_READ_ONLY
#API_KEY=
#API_KEY_READ_ONLY=
#API_ALLOW_FROM=172.22.1.1,127.0.0.1
mail_home is ~/Maildir
MAILDIR_SUB=Maildir
SOGo session timeout in minutes
SOGO_EXPIRE_SESSION=480
DOVECOT_MASTER_USER and DOVECOT_MASTER_PASS must both be provided. No special chars.
Empty by default to auto-generate master user and password on start.
LEAVE EMPTY IF UNSURE
DOVECOT_MASTER_USER=
DOVECOT_MASTER_PASS=
Let’s Encrypt registration contact information
Optional: Leave empty for none
This value is only used on first order!
Setting it at a later point will require the following steps:
ACME_CONTACT=
WebAuthn device manufacturer verification
After setting WEBAUTHN_ONLY_TRUSTED_VENDORS=y only devices from trusted manufacturers are allowed
root certificates can be placed for validation under mailcow-dockerized/data/web/inc/lib/WebAuthn/rootCertificates
WEBAUTHN_ONLY_TRUSTED_VENDORS=n
![](https://community.mailcow.email/assets/files/2023-07-15/1689389963-874029-screenshot-6.png)
![](https://community.mailcow.email/assets/files/2023-07-15/1689389964-216396-screenshot-5.png)
![](https://community.mailcow.email/assets/files/2023-07-15/1689389964-417004-screenshot-4.png)
![](https://community.mailcow.email/assets/files/2023-07-15/1689389964-531221-screenshot-3.png)
![](https://community.mailcow.email/assets/files/2023-07-15/1689389964-643840-screenshot-2.png)
![](https://community.mailcow.email/assets/files/2023-07-15/1689389964-724854-screenshot-1.png)
![](https://community.mailcow.email/assets/files/2023-07-15/1689389964-828862-screenshot-75.png)
