Morgen,
Port 80 ist verfügbar, habe diesen auch probeweise direkt durchgereicht.
anbei das log:
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Waiting for Docker API…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Docker API OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Waiting for Postfix…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Postfix OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Waiting for Dovecot…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Dovecot OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Waiting for database…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Database OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Waiting for Nginx…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Nginx OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:02 CEST 2023 - Waiting for resolver…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:03 CEST 2023 - Resolver OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:03 CEST 2023 - Waiting for domain table…
mailcowdockerized-acme-mailcow-1 | OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:03 CEST 2023 - Initializing, please wait…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:03 CEST 2023 - Using existing domain rsa key /var/lib/acme/acme/key.pem
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:03 CEST 2023 - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:05 CEST 2023 - No A or AAAA record found for hostname autodiscover.xxxx-domain2.de
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:05 CEST 2023 - No A or AAAA record found for hostname autoconfig.xxxx-domain2.de
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:05 CEST 2023 - Found A record for autodiscover.domain1.net: 80.22.xx.xx
mailcowdockerized-acme-mailcow-1 | (skipping check, returning 0)
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:05 CEST 2023 - Confirmed A record 80.22.xx.xx
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:05 CEST 2023 - Found A record for autoconfig.domain1.net: 80.22.xx.xx
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:07 CEST 2023 - No A or AAAA record found for hostname autodiscover.domain.de
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:08 CEST 2023 - Found AAAA record for autoconfig.domain: 2a01:238:20xxxxxxx::1141 - skipping A record check
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Confirmed AAAA record with IP 2a01:0238:020xxxxxxx:1141
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Found A record for mail.domain1.net: 80.22.xx.xx
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Confirmed A record 80.22.xx.xx
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Certificate /var/lib/acme/mail.domain1.net/cert.pem missing or changed domains ‘mail.domain1.net autoconfig.domain1.net autoconfig.domin.de autodiscover.domain1.net’ - start obtaining
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Creating backups in /var/lib/acme/backups/mail.domain1.net/2023-06-23_09_28_09 …
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Checking resolver…
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Resolver OK
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:28:09 CEST 2023 - Using command acme-tiny –account-key /var/lib/acme/acme/account.pem –disable-check –csr /var/lib/acme/mail.domain1.net/acme.csr –acme-dir /var/www/acme/
mailcowdockerized-acme-mailcow-1 | Parsing account key…
mailcowdockerized-acme-mailcow-1 | Parsing CSR…
mailcowdockerized-acme-mailcow-1 | Found domains: mail.domain1.net, autodiscover.domain1.net, autoconfig.domin.de, autoconfig.domain1.net
mailcowdockerized-acme-mailcow-1 | Getting directory…
mailcowdockerized-acme-mailcow-1 | Traceback (most recent call last):
mailcowdockerized-acme-mailcow-1 | File “/usr/bin/acme-tiny”, line 8, in <module>
mailcowdockerized-acme-mailcow-1 | sys.exit(main())
mailcowdockerized-acme-mailcow-1 | File “/usr/lib/python3.10/site-packages/acme_tiny.py”, line 195, in main
mailcowdockerized-acme-mailcow-1 | signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact, check_port=args.check_port)
mailcowdockerized-acme-mailcow-1 | File “/usr/lib/python3.10/site-packages/acme_tiny.py”, line 105, in get_crt
mailcowdockerized-acme-mailcow-1 | directory, _, _ = _do_request(directory_url, err_msg=“Error getting directory”)
mailcowdockerized-acme-mailcow-1 | File “/usr/lib/python3.10/site-packages/acme_tiny.py”, line 46, in do_request
mailcowdockerized-acme-mailcow-1 | raise ValueError(“{0}:\nUrl: {1}\nData: {2}\nResponse Code: {3}\nResponse: {4}”.format(err_msg, url, data, code, resp_data))
mailcowdockerized-acme-mailcow-1 | ValueError: Error getting directory:
mailcowdockerized-acme-mailcow-1 | Url: https://acme-v02.api.letsencrypt.org/directory
mailcowdockerized-acme-mailcow-1 | Data: None
mailcowdockerized-acme-mailcow-1 | Response Code: None
mailcowdockerized-acme-mailcow-1 | Response: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Hostname mismatch, certificate is not valid for ‘acme-v02.api.letsencrypt.org’. (ssl.c:997)>
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:29:15 CEST 2023 - Failed to obtain certificate /var/lib/acme/mail.domain1.net/cert.pem for domains ‘mail.domain1.net autoconfig.domain1.net autoconfig.domain.de autodiscover.domain1.net’
mailcowdockerized-acme-mailcow-1 | Fri Jun 23 09:29:15 CEST 2023 - Some errors occurred, retrying in 30 minutes…
