The machine is a vserver that was freshly installed before installing mailcow. I have been following the instruction. The only customization–apart from my own variables like hostname, domain etc.–I have done so far is enabling HTTPS redirects for port 80 and installing Nextcloud with the install script provided by mailcow.
Edit: I am trying to connect via StartTLS on port 587 with my username “emailuser@example.org” and the user’s password. Whether the authentication is encrypted or plain password doesn’t change the result. connecting via SSL/TLS on port 465 doesn’t change things.
Log Files
The Postfix logfiles don’t show any activity when I try to connect via smtp. Dovecot show the successful connection afterwards (claws reads new message via imap after every attempt of sending an email)
DNS resolving
comes back clear, all records are there
Routing table
The server is a vserver that is connected directly to the web.
Native postfix Service disabled and stopped?
postfix was never installed on the machine
Nmap from the outside:
Starting Nmap 7.60 ( https://nmap.org ) at 2020-07-26 17:48 UTC
Nmap scan report for mail.example.com (1.1.1.1)
Host is up (0.10s latency).
rDNS record for 1.1.1.1: www.example.com
Not shown: 989 filtered ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
110/tcp open pop3
143/tcp open imap
443/tcp open https
465/tcp open smtps
587/tcp open submission
993/tcp open imaps
995/tcp open pop3s
Nmap on the machine for localhost:
Starting Nmap 7.80 ( https://nmap.org ) at 2020-07-26 19:50 CEST
Nmap scan report for localhost (127.0.0.1)
Host is up (0.0000040s latency).
Not shown: 990 closed ports
PORT STATE SERVICE
22/tcp open ssh
25/tcp open smtp
80/tcp open http
110/tcp open pop3
143/tcp open imap
443/tcp open https
465/tcp open smtps
993/tcp open imaps
995/tcp open pop3s
