Hello! I’ve been trying to further secure my self-hosted Mailcow instance. Right now, I am port forwarding so that the A record points to my IP correctly. I tried using Cloudflare tunnels and turned off proxying and that did work however when I used https://mail-tester.com I got a 8.9/10 score since my rDNS records weren’t being recognized when using the tunnel. I was wondering if this is an acceptable score since using Cloudflare tunnels would be preferred.
Thanks in advance.
it depends. I got only 8.1 and the reason was how the test email was written.
It checks for newsletters, and not for private mails.
    If a wrong PTR is the reason for the reduced score, I’d say this being more important. A PTR should be valid if you want to reliably send emails.
    Does Cloudflare Tunnels actually assign you a static IP? Not sure if you can change the PTR/rDNS for that IP.
      pkernstock Thanks for the reply, yes, the reduced score is mainly from no reverse DNS (which is what I assume you mean when you said “PTR”). I’m not sure about the static IP, but since I turned off proxying I thought it would use my IP.
      Thanks!
      esackbauer Thanks for the reply, the reduced score is due to there being no reverse DNS recognised.
      Thanks!
      pkernstock I looked on the Cloudflare dashboard and it does seem you can add PTR records! I’m unsure what to put in the record though, as I’d be using a Cloudflare tunnel. Would I just put my public IP?
      Thanks in advance.
      I don’t know. The PTR needs to be set from the owner of the IP and is usually done from the owner of the IP. That having said - are you sure that you have public-reachable, static IPs with your pre-defined ports required for emailing when using Cloudflare tunnel?
        pkernstock Thanks for the fast reply, I tried turning off port forwarding on my router and setting up a Cloudflare Tunnel and I could send emails to mail-tester.com. When I ran the test, I got a score of 8.9/10 again due to no rDNS being recognized. I added a PTR record but it didn’t allow me to add my public IP so I ended up just pointing the domain to itself which didn’t work.
        Thanks!
