jtdoank Log in at Mailcow as an mailbox user (not at SOGo), under Mailbox -> Settings click on Reset Active Sync Device Cache -> Reset Now.
But that doesn’t sound like the problem that the EAS cache could solve. Are the accounts with the mailboxes still in Mailcow? You only see the error in SOGo?
    6 days later
    chesseling
    Hi so sorry late reply,
    already reset but still no result
    Yes, the account still on the mailcow and even the message also still count as it is
    also
    Yes the error is only on SOGo
    but its seems the dovecot problem
    did anyone ever facing this problem?
    7 days later
    update
    this morning, Indonesian time
    suddenly the sogo it works
    even i didn’t do anything
    just now i tried update the mailcow
    and
    sadly it happen again
    no mailbox selected on sogo
    7 days later
    just check and as I expected,
    the mailbox is works
    hehehe
    nothing to do from last check
    2 years later
    jtdoank
    Ok.
    actually I am getting like this “504 gateway time-out” while checking the DNS of the domain, Did you got like this?Then “NO MAILBOX SELECTED” in sogo .
    I dont have like yours
    At that time all is working perfectly but sogo no mailbox selected
      4 months later
      i just update the mailcow-dockerize and voila, the mailbox is available
