Hello
i tried to get a mailcow instance up and running on my Debian 11 server with docker and every service starting fine, but the dovecot service has the following error after startup:
Uptime: 28799  Threads: 11  Questions: 30560  Slow queries: 0  Opens: 105  Open tables: 96  Queries per second avg: 1.061
The user `vmail' is already a member of `tty'.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:00:20 --:--:--     0
curl: (28) Resolving timed out after 15000 milliseconds
Warning: Problem : timeout. Will retry in 1 seconds. 10 retries left.
Warning: Problem : timeout. Will retry in 2 seconds. 9 retries left.
Warning: Problem : timeout. Will retry in 4 seconds. 8 retries left.
Warning: Problem : timeout. Will retry in 8 seconds. 7 retries left.
Warning: Problem : timeout. Will retry in 16 seconds. 6 retries left.
Warning: Problem : timeout. Will retry in 32 seconds. 5 retries left.
Warning: Problem : timeout. Will retry in 64 seconds. 4 retries left.
I read that this is some error about the iptable configuration and that docker blocks it and i tried some solution like switching to legacy iptables but then the setup didnt even start and docker has errors.
Had has someone else this problem and any working solutions for his setup? I would really appreciate help with this topic.
Thanks and best regards
DerHerrGammler
25 days later
  • paase
      Moolevel 0
    Moin,
    ich habe das gleiche Problem.
    Or must be write in english?
    Grüße
    Pascal
    Wenn jemand auf deutsch die Lösung für dieses Problem schreibt, ist das für mich kein Problem, ich schreib aus reflex auf english, weil ich denke, dass man damit die breitere Masse ansprechen kann.
    Ich hab bisher noch nicht die Lösung gefunden von daher, wenn jemand das Problem auch hatte und sagen könnte wie er es gelöst hat wäre das fantastisch.
    Gruß
    DerHerrgammler
    • paase
        Moolevel 0
      hab eine quick and dirty Lösung, die allerdings das Runterladen der SpamAssassin Rules einfach ausschaltet.
      cd /opt/mailcow-dockerized/
      docker-compose exec dovecot-mailcow /bin/bash
      grep -n sa-rule docker-entrypoint.sh
      die Ausgabe sollte ungefähr so aussehen
      421:/usr/local/bin/sa-rules.sh
      Die 421 ist die Zeilennummer
      sed -i -e 421c"#/usr/local/bin/sa-rules.sh" docker-entrypoint.sh
      Ersetzt die Zeile mit dem gleichen Inhalt, kommentiert sie nur aus mittels #.
      Anschließen Strg+D
      docker-compose restart dovecot-mailcow
      Ist keine persistente Lösung, nach jedem Update ist die Änderung weg.
        5 months later
        paase Hi Danke für diesen Workaround. Ich habe mich ein bisschen rumgespielt und zwar spinnt der cURL Befehlt “curl http://www.spamassassin.heinlein-support.de/
        $(dig txt 1.4.3.spamassassin.heinlein-support.de +short | tr -d ‘”’ | tr -dc ‘0-9’).tar.gz –output /tmp/sa-rules-heinlein.tar.gz" rum.
        Habe festgestellt dass anscheinend IPs geblockt werden von dieser Seite? Komme mit meiner Static IP nicht mehr drauf auf die Seite, mit meiner 2ten IP jedoch problemlos.
        LG,
        Tazuma
        a year later
        Hallo, ich kann das selbe Phänomen nach wie vor auch nach über einem Jahr beobachten. Gibt es hierfür einen dauerhaften Fix? nach jedem Update die sed befehle aufzuführen finde ich nicht sehr sinnvoll.
        • esackbauer
          Moolevel 347
        Da ihr so wenige seid die damit Probleme haben würde ich auf eine “problematische” Konfiguration eurer Hosts tippen.
        Am besten machst du ein Github Issue auf, mit genauer Beschreibung deines Systems und des Fehlerbildes.
