Hi!
I migrated my mailcow instance last week and wanted to add two additional_sans today. For some reason, even after using docker-compose up -d
, ACME doesn’t use the newly added SANs and fallsback to the old config. No changes whatsoever.
mailcow.conf is on 755. Any ideas?
English
ACME not recognizing added ADDITIONAL_SAN in mailcow.conf
have you made sure there’s no space after the = ? that’s what sc*d me up…
I’m a newbie myself so hopefully I’m not boring you, but what I’d try first as root
source ./mailcow.conf ; echo $ADDITIONAL_SAN
if your domains are showing, the config isn’t the problem at least.
