Hey,
my parents aren´t able to send out mails from my mailcow.
They get blocked because their IP is blocked by spamhaus. ISP is Telekom.
Trying to get a new IP hasn´t resolved the problem.
Any suggestions on how to unblock it in mailcow?
NOQUEUE: reject: RCPT from [XXX.XXX.XXX.XXX]:58054: 550 5.7.1 Service unavailable; client [XXX.XXX.XXX.XXX] blocked using zen.spamhaus.org; from=xxx@xxx.xxx, to=xxx@xxx.xxx, proto=ESMTP, helo=<smtpclient.apple>
    What port are they using for SMTP? Are SMTP credentials set in the email client?
    hey,
    465 is set with correct credentials
    9 days later
    Seems you have only 2 options:
    1. Explicitly whitelist your parent’s ISP CIDR block.
    2. Contact Spamhaus to get more information on being listed. Maybe their machines have been compromised and are part of a botnet? Or the ISP’s CIDR block has been listed for similar reasons.
    haiopaii they do have a Static IP didn’t they?
