Moo’ya!
I should add a single domain which is (at the moment) unable to fulfill the requirements for DKIM. Is it possible in Mailcow to disable DKIM for a single specific domain? I know that i can delete the key but dunno if that is sufficient.
Thanks in advance
Chris
