We are having a fair amount of duplicate Message-id problems from alibaba / aliexpress. I would like to get this solved. I am happy to pay for pigeonhole to be updated / sponsor this fix. I tried to sign up for support and the website hangs. Does anyone have any suggestions on how to help move this along?
I can’t help with your problem, but I was wondering why mailcow contained an older version of Pigeonhole, especially since mailcow simply installs the Alpine Linux package of dovecot-pigeonhole-plugin when GitHub Icon building the Dovecot Docker image
Also it is the lastest package available (see the .21):
root@mailcow# docker compose exec dovecot-mailcow apk info dovecot-pigeonhole-plugin
dovecot-pigeonhole-plugin-2.3.21-r17 description:
Sieve and managesieve plugin for Dovecot
But looking at the respective git.alpinelinux.org Icon Alpine package souces
, they are explicitly using dovecot-pigeonhole-0.5.19.tar.gz to build the Pigeonhole sub-package for Dovecot.
According to the dovecot.org Icon 0.5.21 release notes
, Dovecot indeed fixed a problem with Message-ID headers.
0.5.20 (and even 0.5.19) were just GitHub Icon releases to keep the version numbers synced
between Dovecot and Pigeonhole.
Long story short: If this fix in 0.5.21 is the solution to your problems, either Alpine must update their package sources to .21 (which would also be less misleading regarding the version number) or mailcow should use a different way to install the current version of Pigeonhole.
    accolon Thank you for all of that explanation. This makes a lot of sense as to why the older version is happening.
    Ideally, it would be great to get pigeonhole updated so the fix is elegant. I see there is lobbying of other groups that may be necessary.
    Less ideally here is the scenario:
    The original email comes in with this message-id:
    Message-ID: 9833819030155984$ba6dfc7f00d0457e96aaa5b6ecb7a02e
    Because it is malformed a new message-id is added to the headers like
    Message-ID: <dovecot-sieve-1720341929-837352-1@72f9e7376ada>
    Then reputable mail servers reject the forward on the basis that there are multiple message-ids. Any work around hack idea where I can remove one of the message-ids in a way that I can comment out later when the fix ultimately makes it out?
    5 days later
    I’ve added the following at the end of
    data/conf/postfix/anonymize_headers.pcre
    as a VERY hacky solution for the moment, that solved the issue:
    /^(?i)Message-ID:\s+<dovecot-sieve.*?@.*?>/ IGNORE
    Don’t forget to reload postfix with:
    docker compose exec postfix-mailcow postfix reload
    Mechanic - I love you. It works perfectly until a proper solution is implemented.
    Thank you.
    Thanks for the heads up. I requested they update the version and I also filed a support ticket with mailcow who said they would request it as well. Happy to see everyone working together.
    6 days later
    It would be great to see this finally resolved, looks like there might be some light at the end of the tunnel!
    6 months later
    • esackbauer
      Moolevel 347
    mechanic
    Please bump the issue on github (or open an issue)
    mechanic
    Confirmed with Dev team that this is scheduled next update.
    “we plan the integration of this update for the february 2025-02 update.”
