Hi, I noticed when sending emails in thunderbird/deltachat or in sogo it takes about 30 seconds to complete and I’m insure why it takes so much time. I use 993 and 465 ports and here are logs:
postfix:
08/18/2022, 11:41:16 PM info statistics: max cache size 4 at Aug 19 01:31:32
08/18/2022, 11:41:16 PM info statistics: max connection count 1 for (submission:141.98.10.81) at Aug 19 01:31:32
08/18/2022, 11:41:16 PM info statistics: max connection rate 1/60s for (submission:141.98.10.81) at Aug 19 01:31:32
08/18/2022, 11:40:33 PM info disconnect from unknown[141.98.11.74] ehlo=2 starttls=1 auth=0/1 quit=1 commands=4/5
08/18/2022, 11:40:33 PM warning warning: unknown[141.98.11.74]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
08/18/2022, 11:40:27 PM info Anonymous TLS connection established from unknown[141.98.11.74]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
08/18/2022, 11:40:22 PM info disconnect from unknown[141.98.11.112] ehlo=2 starttls=1 auth=0/1 quit=1 commands=4/5
08/18/2022, 11:40:22 PM warning warning: unknown[141.98.11.112]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
08/18/2022, 11:40:22 PM info connect from unknown[141.98.11.74]
08/18/2022, 11:40:22 PM warning warning: hostname srv-141-98-11-74.serveroffer.net does not resolve to address 141.98.11.74: Name or service not known
08/18/2022, 11:40:20 PM info Anonymous TLS connection established from unknown[141.98.11.112]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
08/18/2022, 11:40:13 PM info connect from unknown[141.98.11.112]
08/18/2022, 11:40:13 PM warning warning: hostname swear.medyamol.com does not resolve to address 141.98.11.112: Name or service not known
08/18/2022, 11:40:11 PM info disconnect from unknown[45.125.65.37] ehlo=2 starttls=1 auth=0/1 quit=1 commands=4/5
08/18/2022, 11:40:11 PM warning warning: unknown[45.125.65.37]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
08/18/2022, 11:40:09 PM info Anonymous TLS connection established from unknown[45.125.65.37]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
08/18/2022, 11:40:04 PM info connect from unknown[45.125.65.37]
08/18/2022, 11:38:49 PM info disconnect from unknown[141.98.10.203] ehlo=2 starttls=1 auth=0/1 quit=1 commands=4/5
08/18/2022, 11:38:49 PM warning warning: unknown[141.98.10.203]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
08/18/2022, 11:38:46 PM info Anonymous TLS connection established from unknown[141.98.10.203]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
08/18/2022, 11:38:40 PM info connect from unknown[141.98.10.203]
08/18/2022, 11:38:13 PM info disconnect from keeper-us-east-1d.mxtoolbox.com[18.209.86.113] ehlo=1 mail=1 rcpt=0/1 quit=1 commands=3/4
08/18/2022, 11:38:13 PM info NOQUEUE: reject: RCPT from keeper-us-east-1d.mxtoolbox.com[18.209.86.113]: 554 5.7.1 <test@mxtoolboxsmtpdiag.com>: Relay access denied; from=<supertool@mxtoolboxsmtpdiag.com> to=<test@mxtoolboxsmtpdiag.com> proto=ESMTP helo=<keeper-us-east-1d.mxtoolbox.com>
08/18/2022, 11:38:09 PM info connect from keeper-us-east-1d.mxtoolbox.com[18.209.86.113]
08/18/2022, 11:38:04 PM info PASS NEW [18.209.86.113]:10546
08/18/2022, 11:38:01 PM info addr 18.209.86.113 listed by domain hostkarma.junkemailfilter.com as 127.0.0.1
08/18/2022, 11:38:01 PM info addr 18.209.86.113 listed by domain hostkarma.junkemailfilter.com as 127.0.1.1
08/18/2022, 11:38:01 PM info Look up 18.209.86.113 on whitelist, result 200 DUNNO
08/18/2022, 11:38:01 PM info CONNECT from [18.209.86.113]:10546 to [172.16.0.253]:25
08/18/2022, 11:37:51 PM info A7CC884C19B0: removed
08/18/2022, 11:37:51 PM info A7CC884C19B0: to=<deltachat-community@hispanilandia.net>, relay=box.hispanilandia.net[51.15.127.36]:25, delay=26, delays=25/0.02/0.66/0.3, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as 0B1527E095)
08/18/2022, 11:37:50 PM info Trusted TLS connection established to box.hispanilandia.net[51.15.127.36]:25: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (2048 bits)
08/18/2022, 11:37:50 PM info A7CC884C19B0: from=<esmail@esmailelbob.xyz>, size=1611, nrcpt=1 (queue active)
08/18/2022, 11:37:26 PM info A7CC884C19B0: message-id=<Mr.DP7SrcSWkFk.L67FO4XRYah@esmailelbob.xyz>
08/18/2022, 11:37:26 PM info A7CC884C19B0: replace: header Received: from [127.0.0.1] (unknown [102.45.60.41])??(using TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)?? key-exchange X25519 server-signature RSA-PSS (4096 bits) server-digest SHA256)?? from unknown[102.45.60.41]; from=<esmail@esmailelbob.xyz> to=<deltachat-community@hispanilandia.net> proto=ESMTP helo=<[127.0.0.1]>: Received: from [127.0.0.1] (localhost [127.0.0.1]) by localhost (Mailerdaemon) with ESMTPSA id A7CC884C19B0??for <deltachat-community@hispanilandia.net>; Fri, 19 Aug 2022 01:37:25 +0200 (EET)
08/18/2022, 11:37:25 PM info A7CC884C19B0: client=unknown[102.45.60.41], sasl_method=PLAIN, sasl_username=esmail@esmailelbob.xyz
08/18/2022, 11:37:24 PM info Anonymous TLS connection established from unknown[102.45.60.41] to mail.esmailelbob.xyz: TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits) key-exchange X25519 server-signature RSA-PSS (4096 bits) server-digest SHA256
08/18/2022, 11:37:20 PM info connect from unknown[102.45.60.41]
08/18/2022, 11:37:20 PM warning warning: hostname host-102.45.60.41.tedata.net does not resolve to address 102.45.60.41: Name or service not known
08/18/2022, 11:37:20 PM info disconnect from unknown[102.45.60.41] ehlo=2 starttls=1 auth=1 mail=2 rcpt=2 data=2 quit=1 commands=11
08/18/2022, 11:36:42 PM info disconnect from unknown[141.98.10.84] ehlo=2 starttls=1 auth=0/1 quit=1 commands=4/5
08/18/2022, 11:36:42 PM warning warning: unknown[141.98.10.84]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
08/18/2022, 11:36:37 PM info Anonymous TLS connection established from unknown[141.98.10.84]: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
08/18/2022, 11:36:31 PM info connect from unknown[141.98.10.84]
08/18/2022, 11:36:31 PM warning warning: hostname liferson.de does not resolve to address 141.98.10.84: No address associated with hostname
08/18/2022, 11:36:15 PM info 63D6A84C19B0: removed
08/18/2022, 11:36:15 PM info 63D6A84C19B0: to=<esmail@esmailelbob.xyz>, relay=dovecot[172.16.0.250]:24, delay=21, delays=21/0.01/0/0.21, dsn=2.0.0, status=sent (250 2.0.0 <esmail@esmailelbob.xyz> WAamGe/M/mLCVAAAJHouNA Saved)
08/18/2022, 11:36:15 PM info disconnect from box.hispanilandia.net[51.15.127.36] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
08/18/2022, 11:36:15 PM info 63D6A84C19B0: from=<deltachat-community-bounces@hispanilandia.net>, size=4052, nrcpt=1 (queue active)
08/18/2022, 11:35:54 PM info 63D6A84C19B0: message-id=<Mr.9J9SeQH8Gnz.3BBObGwDz6w@posteo.at>
Dovecot:
08/18/2022, 11:41:01 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:41:01 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:41:01 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:41:01 PM info lmtp(22044): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:41:01 PM info lmtp(22044): Connect from 172.16.0.6
08/18/2022, 11:41:00 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:39:58 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:39:58 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:39:58 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:39:58 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:39:58 PM info lmtp(21698): Connect from 172.16.0.6
08/18/2022, 11:39:09 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:39:09 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:39:09 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:39:09 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:39:09 PM info lmtp(21698): Connect from 172.16.0.6
08/18/2022, 11:38:22 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:38:22 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:38:22 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:38:22 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:38:22 PM info lmtp(21698): Connect from 172.16.0.6
08/18/2022, 11:37:56 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:37:56 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:37:56 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:37:56 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:37:56 PM info lmtp(21698): Connect from 172.16.0.6
08/18/2022, 11:37:19 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:37:19 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:37:19 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:37:19 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:37:19 PM info lmtp(21698): Connect from 172.16.0.6
08/18/2022, 11:36:56 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:36:56 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:36:56 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:36:56 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:36:56 PM info lmtp(21698): Connect from 172.16.0.6
08/18/2022, 11:36:29 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:36:29 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:36:29 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:36:29 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:36:29 PM info lmtp(21698): Connect from 172.16.0.6
08/18/2022, 11:36:15 PM info lmtp(21698): Disconnect from 172.16.0.253: Logged out (state=READY)
08/18/2022, 11:36:15 PM info lmtp(esmail@esmailelbob.xyz)<21698><WAamGe/M/mLCVAAAJHouNA>: sieve: msgid=<Mr.9J9SeQH8Gnz.3BBObGwDz6w@posteo.at>: fileinto action: stored mail into mailbox 'DeltaChat'
08/18/2022, 11:36:15 PM info lmtp(21698): Connect from 172.16.0.253
08/18/2022, 11:35:59 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:35:29 PM info managesieve-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:35:29 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250
08/18/2022, 11:35:29 PM info imap-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=172.16.0.6, lip=172.16.0.250, TLS, TLSv1.3 with cipher TLS_AES_256_GCM_SHA384 (256/256 bits)
08/18/2022, 11:35:29 PM info lmtp(21698): Disconnect from 172.16.0.6: Logged out (state=MAIL FROM)
08/18/2022, 11:35:29 PM info lmtp(21698): Connect from 172.16.0.6
and here mailbox diagnose https://mxtoolbox.com/SuperTool.aspx?action=smtp%3amail.esmailelbob.xyz&run=toolpage
I really need help as I’m confused and thanks in advance
