English
Lets Encrypt suddenly stops working.
Hmm, updated to latest version? nginx running, no errors?
Maybe it’s a IPv6 vs IPv4 issue? Do both A and AAAA Records point to your server and do both work?
i dont use IPv6 and i did not change anything. also the url is working from random computers. so dns settings should be correct.
AudiWolf MrYoshii I don’t understand the fix, what in detail have you done? Since a few days I get also the following issue. Before everything was working fine. Please help me out.
10.08.2022, 23:41:12 mail.domain.tld - Use SKIP_LETS_ENCRYPT=y in mailcow.conf to skip it permanently.
10.08.2022, 23:41:12 mail.domain.tld - Cannot validate any hostnames, skipping Let's Encrypt for 1 hour.
10.08.2022, 23:41:12 mail.domain.tld - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname mail.domain.tld (DNS returned XXXX:YYYY:XXXX:YYYY:0000:0000:0000:0001)
10.08.2022, 23:41:12 mail.domain.tld - Found AAAA record for mail.domain.tld: 2a01:4f8:1c1e:d0ba::1 - skipping A record check
10.08.2022, 23:41:12 mail.domain.tld - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname autoconfig.domain.tld (DNS returned XXXX:YYYY:XXXX:YYYY:0000:0000:0000:0001)
10.08.2022, 23:41:12 mail.domain.tld - Found AAAA record for autoconfig.domain.tld: 2a01:4f8:1c1e:d0ba::1 - skipping A record check
10.08.2022, 23:41:12 mail.domain.tld - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname autodiscover.domain.tld (DNS returned XXXX:YYYY:XXXX:YYYY:0000:0000:0000:0001)
10.08.2022, 23:41:12 mail.domain.tld - Found AAAA record for autodiscover.domain.tld: 2a01:4f8:1c1e:d0ba::1 - skipping A record check
10.08.2022, 23:41:12 mail.domain.tld - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname mta-sts.domain.tld (DNS returned XXXX:YYYY:XXXX:YYYY:0000:0000:0000:0001)
10.08.2022, 23:41:12 mail.domain.tld - Found AAAA record for mta-sts.domain.tld: 2a01:4f8:1c1e:d0ba::1 - skipping A record check
10.08.2022, 23:41:11 mail.domain.tld - Found AAAA record for autoconfig.domain.tld: 2a01:4f8:1c1e:d0ba::1 - skipping A record check
10.08.2022, 23:41:11 mail.domain.tld - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname autodiscover.domain.tld (DNS returned XXXX:YYYY:XXXX:YYYY:0000:0000:0000:0001)
10.08.2022, 23:41:11 mail.domain.tld - Found AAAA record for autodiscover.domain.tld: 2a01:4f8:1c1e:d0ba::1 - skipping A record check
10.08.2022, 23:41:11 mail.domain.tld - Cannot match your IP 0000:0000:0000:0000:0000:0000:0000:0000 against hostname mta-sts.domain.tld (DNS returned XXXX:YYYY:XXXX:YYYY:0000:0000:0000:0001)
10.08.2022, 23:41:11 mail.domain.tld - Found AAAA record for mta-sts.domain.tld: 2a01:4f8:1c1e:d0ba::1 - skipping A record check
10.08.2022, 23:41:11 mail.domain.tld - OK: abc.def.efg.hij, 0000:0000:0000:0000:0000:0000:0000:0000
10.08.2022, 23:40:32 mail.domain.tld - Detecting IP addresses...
10.08.2022, 23:40:32 mail.domain.tld - Using existing Lets Encrypt account key /var/lib/acme/acme/account.pem
10.08.2022, 23:40:32 mail.domain.tld - Using existing domain rsa key /var/lib/acme/acme/key.pem
10.08.2022, 23:40:32 mail.domain.tld - Initializing, please wait...
10.08.2022, 23:40:32 mail.domain.tld - OK
- Edited
just saw your post.
Helped me a lot.
Couldn’t renew Cert.
After i read the answers, i tried to disable ipv6. and it worked for me.
Just follow step 1. here :
then
docker compose down
docker compose up -d
Finally the cert was created new with a few errors on ipv6.
After that i just did the same and activated ipv6 again.
And now the whole process worked fine.
I know it is a old post, but maybe someone else finds this post and can also solve there problem.
