Dear, I have same issue when trying to update to the latest version.
I had version :
https://github.com/mailcow/mailcow-dockerized/releases/tag/2022-06
My setup :
mailcow@mail:/$ sudo docker version
Client: Docker Engine - Community
Version: 20.10.17
API version: 1.41
Go version: go1.17.11
Git commit: 100c701
Built: Mon Jun 6 23:03:17 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.17
API version: 1.41 (minimum version 1.12)
Git commit: a89b842
Built: Mon Jun 6 23:01:23 2022
Experimental: true
containerd:
Version: 1.6.6
GitCommit: 10c12954828e7c7c9b6e0ea9b0c02b01407d3ae1
runc:
Version: 1.1.2
GitCommit: v1.1.2-0-ga916309
docker-init:
Version: 0.19.0
GitCommit: de40ad0
mailcow@mail:/$
mailcow@mail:/$ docker compose version
Docker Compose version v2.6.0
mailcow@mail:/$ uname -r
5.10.0-16-amd64
When I run the command :
mailcow@mail:/opt/mailcow-dockerized$ sudo ./update.sh -check
checking docker compose version…
Found Compose v2!
Checking internet connection… OK
Checking for newer update script…
remote: Enumerating objects: 745, done.
remote: Counting objects: 100% (676/676), done.
remote: Compressing objects: 100% (229/229), done.
remote: Total 745 (delta 471), reused 623 (delta 446), pack-reused 69
Receiving objects: 100% (745/745), 798.98 KiB | 6.05 MiB/s, done.
Resolving deltas: 100% (481/481), completed with 101 local objects.
From https://github.com/mailcow/mailcow-dockerized
5d14baa4..b6e3e7a6 master -> origin/master
5629d47c..e26d5b8b feature/bootstrap5 -> origin/feature/bootstrap5
f0e27312..b0fd9787 feature/fts-xapian -> origin/feature/fts-xapian
- [new branch] feature/nightly-editions -> origin/feature/nightly-editions
e1db347d..a49305fd hotfix -> origin/hotfix
- [new branch] nightly -> origin/nightly
- [new branch] postfix-myorigin-fix -> origin/postfix-myorigin-fix
7ae7f255..4c105250 staging -> origin/staging
- [new tag] 2022-06a -> 2022-06a
- [new tag] 2022-06b -> 2022-06b
- [new tag] 2022-07 -> 2022-07
Updated 1 path from 34c22c17
update.sh changed, please run this script again, exiting.
Then I got this message
Cannot find docker-compose Standalone.
Please install it manually regarding to this doc site: https://mailcow.github.io/mailcow-dockerized-docs/i_u_m/i_u_m_install/
Any idea ?
Best regards,
Youssef
