Hi there,
are there an uptodate video tutorial which can help me install mailcow on contabo or hetzner vps
i find YouTube Icon this video in german
but is there a similar in english version
thanks
MAGIC
I try this but failed terrribly, it is for more advanced users. I do test based on video tutorials i can follow but mailcow setup sounds chinnese to me. (means unknown)
i usually use plesk and control panel and they both usually come as preinstallable with some hosting providers. is there any hosting provider offering mailcow as preinstalled ready to use vps?
Or are there an easy 1 command to instal it on hetzner?
Thanks
    hosamer Or are there an easy 1 command to instal it on hetzner?
    Well after you installed Docker on your Hetzner instance and cloned the Mailcow repo, it’s actualy just two commands: ;-)
    docker-compose pull
    docker-compose up -d
    But yes, at least a basic understanding on how Docker, the Linux CLI, DNS and a mail server in general are working is required. But that wouldn’t be much different with a “OneClick” installer on a VPS either.
    If you’re not comfortable with that or don’t want to go through the hassle of installing and maintaining it yourself, but just want a working instance with your own domain name, it might be worth checking out their offerings at servercow.de.
