I have a server with installed mailcow but I reinstall the server and mailcow up of it. I restored the previews installation.
Then all seems work well except SOGo.
I reset user password and try again to login without success.
I don’t know what I can try.
SOGo Error: Unhandled error response
Saul
I discover that if I don’t use reverse proxy the login work well.
Saul
Is the mailcow installed per domain? or it is installed on a server and then add as many domains as you want and all can login from mail.example.com
thanks
13 days later
