I find an error when I test the dns in the DOMINI menu, after a long time on all the records it appears to me: 0: php_network_getaddresses: getaddrinfo failed: Try again
what can i check?
thank you very much
  • diekuh
    • volunteer
    Moolevel 110
I think you have a NAT reflection problem. Are you using pfSense/OPNsense in front of mailcow?
It is probably not able to connect to “itself” via public IP.
    hi no I don’t use pfSense / OPNsense, but I’m in nat.
    this thing, however, has been happening for a few days and has not always done so and nothing has been changed on the router (mikrotik).
    But along with this, a problem with the acme container also happened, which was then solved, here you can see the issue mailcow/mailcow-dockerized3588
    thanks for the quick response
    3 years later
    diekuh I have the same problem and use OPNsense. Ports are released and DNS entries are also correct, but the error message still remains. do you have a tip for me?
    regards
    Sakis
    Did you check the firewall requirements are all done properly?
    https://docs.mailcow.email/prerequisite/prerequisite-system/#firewall-ports
    Read it until the end, if you are on a VPS.
    Check if reflexive NAT rules are set up.
    And please check log files. Is something not working besides that DNS check in the GUI?
    a month later
    yes, here is the output.
    # ss -tlpn | grep -E -w '25|80|110|143|443|465|587|993|995|4190'
    LISTEN 0 4096 127.0.0.1:37353 0.0.0.0:* users:(("containerd",pid=110,fd=8))
    LISTEN 0 4096 0.0.0.0:587 0.0.0.0:* users:(("docker-proxy",pid=201309,fd=4))
    LISTEN 0 4096 0.0.0.0:993 0.0.0.0:* users:(("docker-proxy",pid=217750,fd=4))
    LISTEN 0 4096 0.0.0.0:995 0.0.0.0:* users:(("docker-proxy",pid=217723,fd=4))
    LISTEN 0 4096 0.0.0.0:143 0.0.0.0:* users:(("docker-proxy",pid=217772,fd=4))
    LISTEN 0 4096 0.0.0.0:25 0.0.0.0:* users:(("docker-proxy",pid=201388,fd=4))
    LISTEN 0 4096 0.0.0.0:110 0.0.0.0:* users:(("docker-proxy",pid=217794,fd=4))
    LISTEN 0 4096 0.0.0.0:4190 0.0.0.0:* users:(("docker-proxy",pid=217695,fd=4))
    LISTEN 0 4096 0.0.0.0:465 0.0.0.0:* users:(("docker-proxy",pid=201349,fd=4))
    LISTEN 0 4096 [::]:587 [::]:* users:(("docker-proxy",pid=201316,fd=4))
    LISTEN 0 4096 [::]:993 [::]:* users:(("docker-proxy",pid=217759,fd=4))
    LISTEN 0 4096 [::]:995 [::]:* users:(("docker-proxy",pid=217731,fd=4))
    LISTEN 0 4096 [::]:143 [::]:* users:(("docker-proxy",pid=217778,fd=4))
    LISTEN 0 4096 [::]:25 [::]:* users:(("docker-proxy",pid=201395,fd=4))
    LISTEN 0 4096 [::]:110 [::]:* users:(("docker-proxy",pid=217802,fd=4))
    LISTEN 0 4096 [::]:4190 [::]:* users:(("docker-proxy",pid=217703,fd=4))
    LISTEN 0 4096 [::]:465 [::]:* users:(("docker-proxy",pid=201356,fd=4))
    how and where can I check this?
    greetings
    sakis
    8 months later
    My friend, your ports are not open
