I am trying to install mailcow following this guide
https://www.bennetrichter.de/en/tutorials/mailcow-dockerized/
Upon “docker-compose up -d” I received this error:
Error response from daemon: driver failed programming external connectivity on endpoint mailcowdockerized-postfix-mailcow-1 (d5e85e2b810433a112562f98e366458954803baa733a098cb7ff09d564e09a7a): Error starting userland proxy: listen tcp4 0.0.0.0:25: bind: address already in use
Upon running netstat i learned that it was running exim4
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      1094/exim4
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      25407/docker-proxy
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      25426/docker-proxy
tcp6       0      0 ::1:25                  :::*                    LISTEN      1094/exim4
tcp6       0      0 :::443                  :::*                    LISTEN      25412/docker-proxy
tcp6       0      0 :::80                   :::*                    LISTEN      25430/docker-proxy
I don’t remember installing exim4 before this and I also don’t remember it being a requirement on the docs so I’m not sure if I can just uninstall exim4 or how to fix it. I found the error on the official website under https://mailcow.github.io/mailcow-dockerized-docs/troubleshooting/debug-common_problems/#address-already-in-use
however the link it redirects to for a fix is no longer available. Could someone please assist me in this ?
