seligmanns
Hi seligmanns,
Would you mind sharing details of your configuration for having mailcow behind an nginx-proxy/acme-companion combination? I am having some trouble getting this to work - even just the basic reverse proxying element isn’t working for me.
I am using a docker-compose.override.yml file to add the additional VIRTUAL_HOST and VIRTUAL_PORT environment settings for nginx-proxy, and to attach to the network in my separate reverse proxy docker project, and I have changed mailcow.conf to bind to 127.0.0.1 and ports 8080 and 8443 for http and https, but I just get a 500 error from the reverse proxy.
I am using this approach because I would like to use the reverse proxy docker project to be able to handle both mailcow’s docker project and other docker projects for other virtual hosts - but maybe this is just being too complex.
Many thanks,
Ciaran.
