You have to check your MX records,MX must point to mailcow server ,also check reverse proxy settings
    posixaz
    I have only one public IP. The mailcow server uses the same public IP of server1. Also namecheap does not allow IP, only domain e.g. mail.,ydomain.com
    the reverse proxy works, I can access mailcow interface from external networks. The problem is only when recieving emails from external networks.
      posixaz
      This is what my reverse proxy in server1 one looks like looks like:
      server {
         server_name mail.mydomain.com;
         listen 25;
         listen 465;
         listen 587;
         listen 143;
         listen 993;
         listen 110;
         listen 995;
         listen 4190;
          proxy_set_header   X-Real-IP $remote_addr;
          proxy_set_header   X-Scheme $scheme;
          proxy_set_header   X-Forwarded-For $proxy_add_x_forwarded_for;
          proxy_set_header   X-Forwarded-Proto $scheme;
          proxy_set_header   X-Forwarded-Port $server_port;
          proxy_set_header   Host $http_host;
         location / {
           proxy_pass http://local_ip_mailcow_server/;
      listen [::]:443 ssl; # managed by Certbot
      listen 443 ssl; # managed by Certbot
      ssl_certificate ...letsencrypt/live/...
      ssl_certificate_key ...letsencrypt/live/...
      include ...letsencrypt/options-ssl-nginx.conf; # managed by Certbot
      ssl_dhparam ...letsencrypt/ssl-dhparams.pem; # managed by Certbot
       server {
           if ($host = mail.mydomain.com) {
             return 301 https://$host$request_uri;
         } # managed by Certbot
         listen 80;
         listen [::]:80;
         return 404; # managed by Certbot
        idhamari you can try telnet from outside to your 25 port to prove is your postfix-mailcow 25 port accessible from outside
        I got this using: telnet public-ip
        telnet: Unable to connect to remote host: No route to host
        and I got this using nmap -sS public-ip
        PORT STATE SERVICE
        25/tcp open smtp
        80/tcp open http
        110/tcp open pop3
        143/tcp open imap
        443/tcp open https
        465/tcp open smtps
        587/tcp open submission
        993/tcp open imaps
        995/tcp open pop3s
        telnet public-ip 25
        I got Connected to public-ip
        Escape character is ‘^]’.
        you have to see your smtp greeting banner like
        220 your server ESMTP Postcow
        16 days later
        I fixed the nginx but I still have the same behavior.
        I can send/receive to/from mailcow to mailcow
        I can send to google but not recieve with this error:
        The response from the remote server was:
        530 5.7.1 Authentication required
        I can not send/recieve from yahoo
