Hi there, I’m trying to set up mailcow to try it out. I am following these instructions for docker: https://mailcow.github.io/mailcow-dockerized-docs/i_u_m_install/
I have a directory, I am root and I clone the repository. I run the generate_config script, and enter my domain mailcow.example.com, then I edit the config to change bindings as I already have a reverse proxy running (but for the sake of just getting it running I’m not using it quite yet):
HTTP_PORT=8090
HTTP_BIND=127.0.0.1
HTTPS_PORT=8443
HTTPS_BIND=127.0.0.1
With that being the only change I make, I start the container (as root as per instructions):
sudo docker-compose up -d
It starts up some containers then I get a log that looks like this:
WARNING: The WATCHDOG_NOTIFY_EMAIL variable is not set. Defaulting to a blank string.
Creating network "mailcowdockerized_mailcow-network" with driver "bridge"
Creating volume "mailcowdockerized_vmail-vol-1" with default driver
Creating volume "mailcowdockerized_vmail-index-vol-1" with default driver
Creating volume "mailcowdockerized_mysql-vol-1" with default driver
Creating volume "mailcowdockerized_mysql-socket-vol-1" with default driver
Creating volume "mailcowdockerized_redis-vol-1" with default driver
Creating volume "mailcowdockerized_rspamd-vol-1" with default driver
Creating volume "mailcowdockerized_solr-vol-1" with default driver
Creating volume "mailcowdockerized_postfix-vol-1" with default driver
Creating volume "mailcowdockerized_crypt-vol-1" with default driver
Creating volume "mailcowdockerized_sogo-web-vol-1" with default driver
Creating volume "mailcowdockerized_sogo-userdata-backup-vol-1" with default driver
Creating mailcowdockerized_memcached-mailcow_1 ... done
Creating mailcowdockerized_solr-mailcow_1 ... done
Creating mailcowdockerized_clamd-mailcow_1 ... done
Creating mailcowdockerized_unbound-mailcow_1 ... done
Creating mailcowdockerized_watchdog-mailcow_1 ... done
Creating mailcowdockerized_olefy-mailcow_1 ... done
Creating mailcowdockerized_redis-mailcow_1 ... done
Creating mailcowdockerized_dockerapi-mailcow_1 ... done
Creating mailcowdockerized_sogo-mailcow_1 ... done
Creating mailcowdockerized_mysql-mailcow_1 ... done
Creating mailcowdockerized_php-fpm-mailcow_1 ... done
Creating mailcowdockerized_nginx-mailcow_1 ... done
Creating mailcowdockerized_dovecot-mailcow_1 ... done
Creating mailcowdockerized_postfix-mailcow_1 ... done
Creating mailcowdockerized_acme-mailcow_1 ... done
Creating mailcowdockerized_netfilter-mailcow_1 ... done
Creating mailcowdockerized_rspamd-mailcow_1 ... done
Creating mailcowdockerized_ofelia-mailcow_1 ... done
Creating mailcowdockerized_ipv6nat-mailcow_1 ... done
Attaching to mailcowdockerized_memcached-mailcow_1, mailcowdockerized_clamd-mailcow_1, mailcowdockerized_olefy-mailcow_1, mailcowdockerized_sogo-mailcow_1, mailcowdockerized_watchdog-mailcow_1, mailcowdockerized_unbound-mailcow_1, mailcowdockerized_solr-mailcow_1, mailcowdockerized_redis-mailcow_1, mailcowdockerized_dockerapi-mailcow_1, mailcowdockerized_php-fpm-mailcow_1, mailcowdockerized_mysql-mailcow_1, mailcowdockerized_nginx-mailcow_1, mailcowdockerized_postfix-mailcow_1, mailcowdockerized_dovecot-mailcow_1, mailcowdockerized_acme-mailcow_1, mailcowdockerized_netfilter-mailcow_1, mailcowdockerized_rspamd-mailcow_1, mailcowdockerized_ofelia-mailcow_1, mailcowdockerized_ipv6nat-mailcow_1
acme-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
clamd-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
dockerapi-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
dovecot-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
mysql-mailcow_1 | 2022-01-27 11:16:18+13:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.11+maria~focal started.
mysql-mailcow_1 | 2022-01-27 11:16:19+13:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
mysql-mailcow_1 | 2022-01-27 11:16:19+13:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.5.11+maria~focal started.
mysql-mailcow_1 | 2022-01-27 11:16:20+13:00 [Note] [Entrypoint]: Initializing database files
netfilter-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
mysql-mailcow_1 |
mysql-mailcow_1 |
mysql-mailcow_1 | PLEASE REMEMBER TO SET A PASSWORD FOR THE MariaDB root USER !
mysql-mailcow_1 | To do so, start the server, then issue the following commands:
mysql-mailcow_1 |
mysql-mailcow_1 | '/usr/bin/mysqladmin' -u root password 'new-password'
mysql-mailcow_1 | '/usr/bin/mysqladmin' -u root -h password 'new-password'
mysql-mailcow_1 |
mysql-mailcow_1 | Alternatively you can run:
mysql-mailcow_1 | '/usr/bin/mysql_secure_installation'
mysql-mailcow_1 |
mysql-mailcow_1 | which will also give you the option of removing the test
mysql-mailcow_1 | databases and anonymous user created by default. This is
mysql-mailcow_1 | strongly recommended for production servers.
mysql-mailcow_1 |
mysql-mailcow_1 | See the MariaDB Knowledgebase at https://mariadb.com/kb or the
mysql-mailcow_1 | MySQL manual for more instructions.
mysql-mailcow_1 |
mysql-mailcow_1 | Please report any problems at https://mariadb.org/jira
mysql-mailcow_1 |
mysql-mailcow_1 | The latest information about MariaDB is available at https://mariadb.org/.
mysql-mailcow_1 | You can find additional information about the MySQL part at:
mysql-mailcow_1 | https://dev.mysql.com
mysql-mailcow_1 | Consider joining MariaDB's strong and vibrant community:
mysql-mailcow_1 | https://mariadb.org/get-involved/
mysql-mailcow_1 |
mysql-mailcow_1 | 2022-01-27 11:16:22+13:00 [Note] [Entrypoint]: Database files initialized
mysql-mailcow_1 | 2022-01-27 11:16:22+13:00 [Note] [Entrypoint]: Starting temporary server
mysql-mailcow_1 | 2022-01-27 11:16:22+13:00 [Note] [Entrypoint]: Waiting for server startup
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] mysqld (mysqld 10.5.11-MariaDB-1:10.5.11+maria~focal) starting as process 103 ...
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Uses event mutexes
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Number of pools: 1
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Using ARMv8 crc32 instructions
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] mysqld: O_TMPFILE is not supported on /tmp (disabling future attempts)
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Using Linux native AIO
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Initializing buffer pool, total size = 25165824, chunk size = 25165824
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Completed initialization of buffer pool
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: 128 rollback segments are active.
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Creating shared tablespace for temporary tables
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: 10.5.11 started; log sequence number 45094; transaction id 20
nginx-mailcow_1 | 2022/01/27 11:16:26 [emerg] 15#15: host not found in upstream "rspamd" in /etc/nginx/conf.d/includes/site-defaults.conf:111
nginx-mailcow_1 | nginx: [emerg] host not found in upstream "rspamd" in /etc/nginx/conf.d/includes/site-defaults.conf:111
nginx-mailcow_1 | nginx: configuration file /etc/nginx/nginx.conf test failed
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] InnoDB: Buffer pool(s) load completed at 220127 11:16:22
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Warning] 'user' entry 'root@f1b3af189ee4' ignored in --skip-name-resolve mode.
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Warning] 'proxies_priv' entry '@% root@f1b3af189ee4' ignored in --skip-name-resolve mode.
mysql-mailcow_1 | 2022-01-27 11:16:22 1 [Note] Event Scheduler: scheduler thread started with id 1
mysql-mailcow_1 | 2022-01-27 11:16:22 0 [Note] mysqld: ready for connections.
mysql-mailcow_1 | Version: '10.5.11-MariaDB-1:10.5.11+maria~focal' socket: '/run/mysqld/mysqld.sock' port: 0 mariadb.org binary distribution
mysql-mailcow_1 | 2022-01-27 11:16:23+13:00 [Note] [Entrypoint]: Temporary server started.
mysql-mailcow_1 | 2022-01-27 11:16:23 5 [Warning] 'proxies_priv' entry '@% root@f1b3af189ee4' ignored in --skip-name-resolve mode.
mysql-mailcow_1 | 2022-01-27 11:16:23+13:00 [Note] [Entrypoint]: Creating database mailcow
mysql-mailcow_1 | 2022-01-27 11:16:23+13:00 [Note] [Entrypoint]: Creating user mailcow
mysql-mailcow_1 | 2022-01-27 11:16:23+13:00 [Note] [Entrypoint]: Giving user mailcow access to schema mailcow
mysql-mailcow_1 |
mysql-mailcow_1 | 2022-01-27 11:16:23+13:00 [Note] [Entrypoint]: Stopping temporary server
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] mysqld (initiated by: root[root] @ localhost []): Normal shutdown
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] Event Scheduler: Killing the scheduler thread, thread id 1
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] Event Scheduler: Waiting for the scheduler thread to reply
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] Event Scheduler: Stopped
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] Event Scheduler: Purging the queue. 0 events
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] InnoDB: FTS optimize thread exiting.
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] InnoDB: Starting shutdown...
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] InnoDB: Dumping buffer pool(s) to /var/lib/mysql/ib_buffer_pool
mysql-mailcow_1 | 2022-01-27 11:16:23 0 [Note] InnoDB: Buffer pool(s) dump completed at 220127 11:16:23
mysql-mailcow_1 | 2022-01-27 11:16:24 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
mysql-mailcow_1 | 2022-01-27 11:16:24 0 [Note] InnoDB: Shutdown completed; log sequence number 45106; transaction id 21
mysql-mailcow_1 | 2022-01-27 11:16:24 0 [Note] mysqld: Shutdown complete
mysql-mailcow_1 |
mysql-mailcow_1 | 2022-01-27 11:16:24+13:00 [Note] [Entrypoint]: Temporary server stopped
mysql-mailcow_1 |
mysql-mailcow_1 | 2022-01-27 11:16:24+13:00 [Note] [Entrypoint]: MariaDB init process done. Ready for start up.
mysql-mailcow_1 |
mysql-mailcow_1 | 2022-01-27 11:16:24 0 [Note] mysqld (mysqld 10.5.11-MariaDB-1:10.5.11+maria~focal) starting as process 1 ...
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Uses event mutexes
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Number of pools: 1
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Using ARMv8 crc32 instructions
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] mysqld: O_TMPFILE is not supported on /tmp (disabling future attempts)
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Using Linux native AIO
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Initializing buffer pool, total size = 25165824, chunk size = 25165824
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Completed initialization of buffer pool
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: 128 rollback segments are active.
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Creating shared tablespace for temporary tables
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: 10.5.11 started; log sequence number 45106; transaction id 20
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] InnoDB: Buffer pool(s) load completed at 220127 11:16:25
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] Server socket created on IP: '::'.
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Warning] 'proxies_priv' entry '@% root@f1b3af189ee4' ignored in --skip-name-resolve mode.
mysql-mailcow_1 | 2022-01-27 11:16:25 1 [Note] Event Scheduler: scheduler thread started with id 1
mysql-mailcow_1 | 2022-01-27 11:16:25 0 [Note] mysqld: ready for connections.
mysql-mailcow_1 | Version: '10.5.11-MariaDB-1:10.5.11+maria~focal' socket: '/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution
olefy-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
ofelia-mailcow_1 | 2022-01-27T11:16:44.015+13:00 scheduler.go:34 ▶ NOTICE New job registered "sogo_sessions" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool expire-sessions ${SOGO_EXPIRE_SESSION} || exit 0\"" - "@every 1m"
ofelia-mailcow_1 | 2022-01-27T11:16:44.015+13:00 scheduler.go:34 ▶ NOTICE New job registered "sogo_ealarms" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-ealarms-notify -p /etc/sogo/sieve.creds || exit 0\"" - "@every 1m"
ofelia-mailcow_1 | 2022-01-27T11:16:44.015+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_fts" - "/usr/bin/curl http://solr:8983/solr/dovecot-fts/update?optimize=true" - "@every 24h"
ofelia-mailcow_1 | 2022-01-27T11:16:44.016+13:00 scheduler.go:34 ▶ NOTICE New job registered "sogo_backup" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool backup /sogo_backup ALL || exit 0\"" - "@every 24h"
ofelia-mailcow_1 | 2022-01-27T11:16:44.016+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_trim_logs" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/trim_logs.sh || exit 0\"" - "@every 1m"ofelia-mailcow_1 | 2022-01-27T11:16:44.016+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_repl_health" - "/bin/bash -c \"/usr/local/bin/gosu vmail /usr/local/bin/repl_health.sh\"" - "@every 5m"
ofelia-mailcow_1 | 2022-01-27T11:16:44.017+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_clean_q_aged" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/clean_q_aged.sh || exit 0\"" - "@every 24h"
ofelia-mailcow_1 | 2022-01-27T11:16:44.017+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_quarantine" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu vmail /usr/local/bin/quarantine_notify.py || exit 0\"" - "@every 20m"
ofelia-mailcow_1 | 2022-01-27T11:16:44.017+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_sarules" - "/bin/bash -c \"/usr/local/bin/sa-rules.sh\"" - "@every 24h"
ofelia-mailcow_1 | 2022-01-27T11:16:44.017+13:00 scheduler.go:34 ▶ NOTICE New job registered "sogo_eautoreply" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu sogo /usr/sbin/sogo-tool update-autoreply -p /etc/sogo/sieve.creds || exit 0\"" - "@every 24h"
ofelia-mailcow_1 | 2022-01-27T11:16:44.017+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_imapsync_runner" - "/bin/bash -c \"[[ ${MASTER} == y ]] && /usr/local/bin/gosu nobody /usr/local/bin/imapsync_runner.pl || exit 0\"" - "@every 1m"
ofelia-mailcow_1 | 2022-01-27T11:16:44.018+13:00 scheduler.go:34 ▶ NOTICE New job registered "dovecot_maildir_gc" - "/bin/bash -c \"source /source_env.sh ; /usr/local/bin/gosu vmail /usr/local/bin/maildir_gc.sh\"" - "@every 30m"
ofelia-mailcow_1 | 2022-01-27T11:16:44.018+13:00 scheduler.go:54 ▶ DEBUG Starting scheduler with 12 jobs
php-fpm-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
redis-mailcow_1 | 1:C 27 Jan 2022 11:16:08.365 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
redis-mailcow_1 | 1:C 27 Jan 2022 11:16:08.365 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=1, just started
redis-mailcow_1 | 1:C 27 Jan 2022 11:16:08.365 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
redis-mailcow_1 | 1:M 27 Jan 2022 11:16:08.368 * monotonic clock: POSIX clock_gettime
redis-mailcow_1 | 1:M 27 Jan 2022 11:16:08.370 * Running mode=standalone, port=6379.
redis-mailcow_1 | 1:M 27 Jan 2022 11:16:08.371 # Server initialized
redis-mailcow_1 | 1:M 27 Jan 2022 11:16:08.371 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
redis-mailcow_1 | 1:M 27 Jan 2022 11:16:08.377 * Ready to accept connections
rspamd-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
postfix-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
sogo-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
solr-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
unbound-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
watchdog-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error
mailcowdockerized_netfilter-mailcow_1 exited with code 1
mailcowdockerized_acme-mailcow_1 exited with code 1
mailcowdockerized_clamd-mailcow_1 exited with code 1
mailcowdockerized_solr-mailcow_1 exited with code 1
mailcowdockerized_olefy-mailcow_1 exited with code 1
mailcowdockerized_unbound-mailcow_1 exited with code 1
mailcowdockerized_postfix-mailcow_1 exited with code 1
mailcowdockerized_dockerapi-mailcow_1 exited with code 1
mailcowdockerized_rspamd-mailcow_1 exited with code 1
mailcowdockerized_php-fpm-mailcow_1 exited with code 1
mailcowdockerized_sogo-mailcow_1 exited with code 1
mailcowdockerized_watchdog-mailcow_1 exited with code 0
mailcowdockerized_dovecot-mailcow_1 exited with code 1
olefy-mailcow_1 | standard_init_linux.go:228: exec user process caused: exec format error...
(cut short due to character limit)
I’m afraid I don’t know where to even start troubleshooting this, as the provided example doesn’t work for me. I am running Ubuntu on a Raspberry Pi 4 (8GM RM).
Many thanks for any help to point me in the right direction.
