heavygale Sure, if it’s mounted on your system. https://mailcow.github.io/mailcow-dockerized-docs/u_e-dovecot-vmail-volume/
bita heavygale actually i dont want to use docker i just need to store user mail box on other serve (that is samba)and i dont know how to locate and config dovecote for this🙄
heavygale Do you run Mailcow? Latest version? In that case you already use docker. Or about what setup are we talking here.
heavygale Can’t help you with that,… this is the mailcow community 😀 How did you set it up, so you now don’t know what your config is? Maybe you should have a look at the dovecot.conf configuration file. https://doc.dovecot.org/configuration_manual/mail_location/Maildir/
